Results 1 to 5 of 5
Thread: Replacement PS / trans cooler options
    Jul 2020
    Atlanta, GA
    As the marauder starts to approach 20 years old, she's showing her age. Rubber hoses are decaying, getting a few leaks here and there. I want to go through and do a pretty good service / replacement, especially on cooling related parts.
    One thing I'm struggling to find a replacement for is the combo PS / trans cooler as mine is leaking at the thermostat. The part # listed here is YW1Z-3F749-AA. I've had zero luck finding that exact part number. What are folks using for replacements now? I know ones from CVPIs should still be available, but I've no idea of cross-compatibility. Every OEM Ford site I've checked insists basically every cooler is compatible with every panther...though I have my doubts lol.
    I'd install an aftermarket trans cooler in series with the factory cooler.
    +1!
    Yes, Keep the factory cooler 'in the loop'.
    Jul 2020
    Atlanta, GA
    +1!
    Definitely planning on it! Problem is, it's leaking, so I need a viable replacement for it to go along with an aftermarket. Hoping there is one from another panther that is cross-compatible?
    Blog Entries
    2
    Be careful you don't block the radiator flow.
  1. Trans cooler
    By Panther in forum Transmissions
    Last Post: 06-03-2012, 05:34 PM
  2. trans cooler
    By 4drpower in forum Transmissions
    Last Post: 11-03-2010, 03:02 PM
  3. Trans cooler
    By Jolly Roger in forum Transmissions
    Last Post: 01-16-2009, 06:31 PM
  4. Trans Cooler
    By DTRMiguel in forum Transmissions
    Last Post: 01-13-2009, 06:41 PM
  5. trans cooler
    By lucenti in forum Transmissions
    Last Post: 10-30-2008, 05:05 AM
