Results 1 to 9 of 9
Thread: Weird running condition.
    Winnipeg,Mb.
    Hey everyone,
    Not sure how to explain this, but I’m having an issue with my car that popped up late last year before I put it away for winter. It’s come back now that I’m driving it again.
    Usually, when I first start the car, everything’s fine. Fuel pressure is good, oil pressure good, temp good, idles fine.The car sounds and runs great. But after driving for ~10-15 mins., the exhaust note changes, it gets deeper, the car feels sluggish, and it almost sounds like there might be an exhaust leak happening. Also a bit of rattling from somewhere under the car that I haven't been able to pinpoint. Doesn't matter outside temp either (started doing it late fall, still does it now with warm weather).
    All vital signs engine wise still appear normal (as noted above). The engine itself sounds fine. No weird noises, no stumbles, misfires, etc.
    I’m leaning towards bad/plugged catalytic convertor, or bad o2 sensors, as the car is exhibiting some of the symptoms of those, but I’m not sure…
    I did maintenance this spring (new plugs, changed oil, filter, cleaned air filter, cleaned MAF sensor). Did a full change of transmission and rear gear oil about 3 years ago.
    The car’s been s/c’d for the last 13 years, almost 95K kms. on it. Magnaflow hi-flow cats have been on for at least 10 years, original stock o2 sensors.
    I have the Xcal3 that came with the Trilogy that I could data log with, but what should I be monitoring? If you need more info, please don't hesitate to ask.
    TIA,
    -Mike
    #6018 of 11,052
    Trilogy #196 - Self-installed
    Stuff done to it. See here.
    Dec 2018
    Albemarle,NC
    Without seeing it judging by the noise & exhaust tone you've probably melted the cats & they are coming apart inside causing the rattling.
    Winnipeg,Mb.
    Thanks for the reply. Forgot to mention there's no check engine light. Yet. I've decided to garage her again until I get this sorted out. Hopefully I can get it to the shop in the next week or so.
    -Mike
    #6018 of 11,052
    Oct 2002
    Orlando, FL
    Not sure if this is your case but when I had an exhaust note change around 82,000 miles, my right rear axle went south. Although when this happens you would see differential fluid in the wheel fender well. This was an issue with early 2003 models as the "soft axle issue(s)". Are you 2003 or 2004?
    rkk
    2003 Marauder 300A (Black)
    Born 5/24/2002
    Drove Home 6/26/2002
    Current mileage: 109,862
    Sequence number 569 of 7,839 / 11,052 total
    Joined the 100K club on 5/29/2019
    Mods:
    McGard wheel locks
    Helmholtz Resonator Delete
    Lower Grille Mod
    LCM updated 07/26/2017
    Winnipeg,Mb.
    Car is a 2003. I had the axles looked at when I first got the car.No fluid in either wheel well.
    -Mike
    #6018 of 11,052
    Oct 2004
    Maybe while in storage a rodent nested in your exhaust.
    Winnipeg,Mb.
    Possible, but it started last fall before putting it away for storage.
    -Mike
    #6018 of 11,052
    Nov 2012
    Sacramento
    Clean Maf, check all intake, look for any leaks on intake? Fuel filter-pump?
    Winnipeg,Mb.
    I cleaned the MAF, and reconnected all clamps. Fuel filter was changed a few years ago. Stock pump still. Fuel pressure good at around 40psi. No drops.
    -Mike
    #6018 of 11,052
  1. Replies: 42
    Last Post: 03-13-2019, 03:11 AM
  2. odd acceleration condition observed
    By 88CuttyClassic in forum Shop Talk
    Last Post: 06-27-2015, 12:09 PM
  3. For Sale a pillar excellent condition
    By nh muscle in forum Marauder-specific Parts for Sale
    Last Post: 07-24-2013, 06:48 AM
  4. question running weird...
    By 4drpower in forum Shop Talk
    Last Post: 11-24-2008, 04:19 PM
  5. no start condition
    By barrytuneup in forum Shop Talk
    Last Post: 09-05-2005, 07:00 AM
