Results 1 to 3 of 3
Thread: MAX RPM of a Lysholm 2.3L Twin Screw
    Sep 2005
    South Florida
    What would be the max RPM of a 2.3L Lysholm supercharger, used on Marauders?
    TCE
    My Garage
    Sep 2004
    Woodbridge, VA
    For the whipple w140ax blower which is the 2.3L, max rpm is 18k.
    ~Chris
    How close to max RPM can you run the Blower before you are just 'beating hot air'....?
  1. Trilogy twin screw
    By DOOM in forum Power Adders
    Last Post: 04-20-2014, 07:43 PM
  2. For Sale Twin Screw Trilogized DTR
    By guspech750 in forum Marauders for Sale
    Last Post: 03-08-2012, 05:34 PM
  3. TWIN SCREW, any updates?
    By knine in forum Shop Talk
    Last Post: 02-03-2008, 07:02 AM
  4. What's the deal with the twin screw?
    By FormulaMarauder in forum Shop Talk
    Last Post: 12-08-2007, 10:04 AM
  5. twin screw supercharger
    By burt ragio in forum Shop Talk
    Last Post: 06-23-2007, 01:00 PM
