Results 1 to 4 of 4
Thread: Climate Control System Operation
    Jan 2023
    Abington, PA
    Question Climate Control System Operation
    I have searched for a little while now, but have not been able to find any information on how the A/C - Heater System functions. I am looking for everything that happens from the minute the car starts.
    I am trying to determine if my system is leaking air.
    As soon as I shut off the key, I can hear vacuum leaking from the heater box. I think someone told me this is normal, but I doesn't make sense to me. I am trying to track down an intermittent stumble in my idle. And after changing the plugs and coils, cleaning the MAF I want to look at vacuum leaks.
    Thanks for any help in learning about the Climate Control System!
    TJ
    Jun 2008
    Waukesha, WI
    Do you have the Ford Maintenance Manual? There is a huge section on HVAC troubleshooting.
    TALALA OK.
    I believe if you have the system off when you turn off the car it opens that outside air door to vent the cab. If you have it on vent already does it make the noise / vacuum sound ?
    03 BLK 9K M.
    07 GT500 13K M.
    98 MARK VIII 75K M. BOUGHT NEW
    21 EXPLORER PLATINUM 3.0
    18 GENESIS G80 5.0
    54 GMC
    Jan 2023
    Abington, PA
    Quote Originally Posted by TORINO View Post
    This is correct! Thanks!
  1. Climate control out
    By FastMerc in forum Interior Electrical/Electronics
    Last Post: 06-03-2016, 12:37 PM
  2. Climate control help!!!
    By H_M_T_81 in forum Shop Talk
    Last Post: 01-04-2013, 08:57 AM
  3. Climate Control System
    By prg333 in forum Shop Talk
    Last Post: 05-05-2012, 01:45 PM
  4. Problem with Climate Control System
    Last Post: 05-07-2010, 07:00 PM
  5. Climate control temp control seems off- AC cools too cold
    By Stranger in the Black Sedan in forum Shop Talk
    Last Post: 07-26-2009, 08:05 PM
