Results 1 to 8 of 8
Thread: Radio Stuck
    Radio Stuck
    I have the radio removal wire inserts from a friend who just installed a new radio, and the right side comes loose, but not the left. In one of the left holes (the top) a short section of pot metal rod got broken off down in there. I had three pieces of brazing rod but not a fourth, so used a piece of rod that broke off, not my finest thought. I figure 1 is down in there. I get the wire insert all the way down, but it wont free the left side. Any ideas? The old radio is junk, I dont care if it gets wrecked but have to get it out. Q: with the right side loose is there something I can wedge down the left side to free it up?
    Just remove the entire dash bezel with the radio if you cant get the radio to release. dont forget the 2 screws above the speedo area.
    So, it's just screws holding the dash bezel in place? I guarantee if it requires snapping molded plastic pieces into place I'm going to break something. Thanks for the info, and I'll take a look.
    Quote Originally Posted by Svashtar View Post
    Just screws (7mm). Put a towel over the steering column cover to prevent scratches. You also have to unplug the headlight switch. Pop it out of the dash and pug it in so the headlights don't stay on.
    There are screws across the bottom of the dash trim also.
    When you cant make them see the light, make them feel the heat.
    Be polite, be professional, but have a plan to kill everybody you meet.
    Radio Stuck
    Thanks, Ill give it a try.
    Just looked and see the two obvious screws above the instruments but nothing else. Dash trim? Does something have to be removed to show those, because Im not seeing them.
    May 2019
    Harrisburg, NC
    Radio Stuck
    Quote Originally Posted by SilverPhoenix View Post
    LOL! Thanks for the link, never thought someone would make a YouTube video about it, but should have checked!
    What a PITA though! Might as well see about those LED bulbs he mentions as well as long as I have it apart. And I wont be removing the radio halfway through like he does.
    What a PITA though! Might as well see about those LED bulbs he mentions as well as long as I have it apart. And I won’t be removing the radio halfway through like he does.
    PM me if you need the LEDs.
  1. Stuck in park
    By svtmerc in forum Community Discussion
    Last Post: 02-23-2022, 06:38 AM
  2. Radio Stuck
    By Svashtar in forum Interior Electrical/Electronics
    Last Post: 07-01-2019, 06:21 PM
  3. I'm stuck and someone's help!
    By TooManyFords in forum Shop Talk
    Last Post: 09-11-2006, 05:30 AM
  4. Stuck
    By jim geary in forum Community Discussion
    Last Post: 12-06-2005, 02:50 PM
  5. Stuck Fan
    By mailman in forum Shop Talk
    Last Post: 12-01-2003, 05:13 PM
