Results 1 to 13 of 13
Thread: Rear Differential Fluid
    Feb 2006
    Rosemount, MN
    What gear oil do you run in your rear differential? I know the owners manual says 75w140, but I think now we're supposed to run 80w90.
    Looking on Rock Auto, the Motorcraft 80w90 shows Premium Rear Axle Lubricant. The Motorcraft 75W140 shows Synthetic.
    I think we supposed to use full Synthetic?
    Rock Auto has a Mobil 1 75w90 that is Synthetic.
    Lehigh Valley, PA
    you have that backwards, the 80W90 call was superseded by 75W140
    run a 75w140 synthetic that has limited slip additives (most should)
    2063/3214
    5377/7838
    Feb 2006
    Rosemount, MN
    Ahhh. Thanks for the help.
    Feb 2006
    Rosemount, MN
    Holy crap it's expensive. Rock Auto has it at $22.89 per quart, whereas 80W90 is only $7.59 per quart.
    Use 75W140 synthetic, Using synthetic negates the need for friction modifier.
    Lehigh Valley, PA
    Go to Walmart, they have tons of 75w140 in stock. No reason to mail order that unless you're going to use something more boutique like Amsoil. Most are around $15 at Walmart.
    2063/3214
    5377/7838
    Sep 2005
    APPLE VALLEY,CA
    How much fluid do we need to change the gear oil?
    Jun 2020
    Los Angeles County, CA
    Whats the reason for the switch to 75w140? I think thats what the police vics use.
    2004 Mercury Marauder, Black
    2008 Crown Victoria P71, Silver
    2010 Crown Victoria P7B, Black
    2010 Crown Victoria P7B, White
    Lehigh Valley, PA
    2.5 quarts, although 2 quarts is usually enough if you're not pulling the axles and getting ALL of the fluid out
    Quote Originally Posted by JVD View Post
    don't know, ask Ford
    2063/3214
    5377/7838
    Sep 2005
    APPLE VALLEY,CA
    So had the differential serviced.
    Replaced the girdle with a Finned one from Amazon’s brand A+. Very reasonably priced. It doesn’t include screws. The seal is RTV. No gasket needed. You just need the RTV to dry enough to finish sealing. The repair person got the screws from O’Reily’s.
    Now for some reason. the alignment is way off. The steering wheel is facing 8 o’clock. It’s on the rack being fixed as I type this.
    Jun 2007
    Whitehall, PA
    Was the steering wheel straight when you drove it to the shop?
    2003 DBP/LF - # 36 sold
    2003 DBP/LF - # 205 sold
    2004 Black - Trilogy #43
    2003 Black - sold
    2004 DTR - sold
    Changing the fluid and replacing the differential cover has NOTHING to do with the front end.
    Sep 2005
    APPLE VALLEY,CA
    Obviously, the alignment has nothing to do with the differential. That’s why it was mysterious. The steering wheel was not straight. I had to drive with it pointing left. It’s all fixed now.
    They also fixed a flat tire( for free)
    Off one of the other Marauders
  1. Rear Differential Fluid
    By 8UWITH6 in forum Shop Talk
    Last Post: 11-13-2012, 07:29 PM
  2. Rear Differential Fluid
    By eric jones in forum Shop Talk
    Last Post: 05-25-2011, 11:22 AM
  3. differential fluid
    By lucenti in forum Shop Talk
    Last Post: 08-22-2008, 05:58 AM
  4. Differential Fluid Viscosity
    By STLR FN in forum Shop Talk
    Last Post: 03-27-2007, 09:01 AM
  5. Rear differential fluid low?
    By TechHeavy in forum Community Discussion
    Last Post: 05-02-2005, 10:55 PM
