Results 1 to 15 of 16
Thread: New rebuilt engine
    Sep 2005
    APPLE VALLEY,CA
    New rebuilt engine
    So today I finally found rebuilt engines for the Marauder. They all say Mustang Cobra DOHC Aliminum engine. Is 8 bolt crank worth ($4600) $800 more than 6 bolt?($3800)
    Aviator engine ($2800) is $1000 less than a Mustang Cobra engine. Which engine is “better” for the Marauder?
    Apr 2010
    South Florida
    Whatever has the newest heads. 8 bolt flex plate is tough to find I think.
    8 bolt crank is forged (OEM Cobra and Manual trans MACH1)
    6 bolt crank is cast (OEM Marauder and Auto trans MACH1)
    Oct 2020
    Chandler Arizona
    I had my 03 MM engine rebuilt. I put in a forged crank , which required an 8 bolt flex plate, which I found and purchased no problem. Chris at ADTR helped.
    One member here, DanielDrives ( or something like that) dropped an Aviator motor in his MM. I can help you contact him. He might still have his damaged orig MM engine.
    '03 Silver Birch. Rebuilt 4.L 32V DOHC, V7-JT blower w/ADTR racing supercharger kit, Shift kit in transmission, stainless works long pipes and cat backs, Ridetech coil-overs front, shocks in back (ADTR kit). Rebuilt calipers, upgraded front rotors, OEM Mercury wheels, [boost, oil P, WB fuel/air, and fuel pressure] gauges. Build duration was Dec 2019 to Mar 2022. Upgraded to 8 rib belt to reduce slip, July-Nov '23. Car broke during tune with Marty Feb '24. Running again May '24. Still needs tune.
    Chances of breaking either crank are practically nil.
    Oil pickup tube and oil pan are unique for the MM, and obsolete.
    Oct 2020
    Chandler Arizona
    uhhh. I bought an oil pan from rockauto. it fit no problem. not sure about the pickup tube.
    Lehigh Valley, PA
    What is your goal, just to have a running/driving car? If the aviator motor is clean save yourself the money and go with that. I did that swap years ago in my 03 Marauder. You'll need to swap the following over from your old motor:
    Intake
    Coolant crossover tube
    Valve covers
    Timing cover
    Oil pickup tube
    Oil pan
    Wiring harness
    2063/3214
    5377/7838
    Sep 2005
    APPLE VALLEY,CA
    I’m looking at a used Automatic Mach 1 engine. What would I need to swap over to the MM?
    Sep 2005
    APPLE VALLEY,CA
    Bump! Any help is appreciated. I’m purchasing a used Mach 1 automatic trans engine. What do I need to change?
    Apr 2010
    South Florida
    Oil pick up tube and oil pan, front timing cover and cam covers, oil filter housing adapter. Lower and upper intakes. Cross over tube. Not too sure about the water pump pipe compare Yours to it. Exhaust manifolds. I would do cooling mod while You're in there. Basically change over everything that looks different than Your engine.
    Scroll up a few posts, someone listed swap items
    Sep 2005
    APPLE VALLEY,CA
    That was for a aviator not Mach 1
    Nov 2009
    NH
    The 3v mustang block, 2005-2010, is the strongest aluminum block. Nemak. The Aluminator is built off this exact block. That’s what I’m using.
    https://www.ebay.com/itm/16610656834...mis&media=COPY
    Sep 2005
    APPLE VALLEY,CA
    How did you turn it into a 4 valve?
  1. For Sale Rebuilt 4 valve Cobra Engine
    By Gee in forum Other Parts for Sale
    Last Post: 12-06-2017, 11:47 AM
  2. For Sale Engine for sale rebuilt
    By Robronnie5 in forum Marauder-specific Parts for Sale
    Last Post: 03-23-2016, 06:35 AM
  3. For Sale 2004 Marauder Engine rebuilt, with heads
    By FudPucker in forum Marauder-specific Parts for Sale
    Last Post: 06-14-2015, 09:22 PM
  4. My Rebuilt Engine.......
    By Marauderjack in forum Community Discussion
    Last Post: 05-11-2015, 05:14 AM
  5. new well rebuilt engine
    By jfclancy in forum North Texas Marauders
    Last Post: 04-22-2014, 02:20 AM
