Results 1 to 14 of 14
Thread: Axle Seal Replacement
    Feb 2006
    Rosemount, MN
    So, I tried to change the axle seals this weekend. I removed the rear wheels, brake calipers and wheel sensors. I removed the rear cover, but couldn't get the axles to push in far enough to remove the C-Clips. There was only about 1/4" of play in and out. What am I doing wrong?
    Feb 2006
    Rosemount, MN
    This is the best video I've ever seen on the replacement of clutches.
    https://www.google.com/search?sca_es...J9h_-t_e0,st:0
    Feb 2006
    Rosemount, MN
    Would removing the pin allow the axles to push in farther?
    TALALA OK.
    Yes the big pin in the center has to be removed. When the seal leaks it usually means the axle and bearing is bad, but maybe just junk seals. u-tube must have video's of pulling axles.
    03 BLK 9K M.
    07 GT500 13K M.
    98 MARK VIII 75K M. BOUGHT NEW
    21 EXPLORER PLATINUM 3.0
    18 GENESIS G80 5.0
    54 GMC
    Dec 2018
    Albemarle,NC
    Did you remove the abs sensors, you need to at least move them in about 3/8" if you don't want them off completely and remove the center pin to get them pushed in far enough to get the c clips out.
    Feb 2006
    Rosemount, MN
    I did remove the ABS sensors, but not the pin. I'll try again this weekend. At least I have the re-useable gasket now.
    Axles, bearings and Motorcraft axle seals were new about 10k miles ago. I Auto-Cross my Marauder, so that gear lube is getting thrown side to side. Should I apply a little RTV on the outside of the bearing to seal it against the axle housing?
    Dec 2018
    Albemarle,NC
    Put the RTV around the perimeter of the seal before you put it in the housing. If you change your mind about a girdled cover a have a couple to sell.
    TALALA OK.
    Be sure the vent is not plugged.
    03 BLK 9K M.
    07 GT500 13K M.
    18 GENESIS G80 5.0
    54 GMC
    Don’t spin the axle when the pins removed, you will spit the spider gears out.
    id just rtv the cover, not the bearings or axle seal
    Feb 2006
    Rosemount, MN
    Quote Originally Posted by TORINO View Post
    Good advise. Thanks.
    Feb 2006
    Rosemount, MN
    Thanks. In the video link I posted, the guy has a good technique for putting them back in.
    Apr 2024
    USA, AZ
    In any case, you'd better check the bearings.
    Nov 2024
    tokoyo
    It sounds like you’re on the right track with removing the axles to replace the seals, but the issue might be related to the axle shaft bearings or the process for accessing the C-clips. Worn or damaged axle bearings near the seal might prevent the axle from moving freely. Inspect the Insulated bearings through the axle tube if possible. If they are seized or overly tight, they could be limiting the axle's movement.
    Feb 2006
    Rosemount, MN
    Just an update. I replaced the axle seals with some O'Reilly seals and I ran 7 auto-cross events with no axle seal leaks. Finished 7th out of 22 in my class which I think is good considering I'm running against Mustangs, Camaros and a Hellcat Charger and a Hellcat Challenger.
  1. Blew an axle seal
    By License2Bill in forum Shop Talk
    Last Post: 01-13-2014, 08:38 PM
  2. Bad Axle Seal
    By hugojax in forum Steering, Suspension & Brakes
    Last Post: 11-10-2013, 12:51 AM
  3. Rear Axle Seal Replacement
    By Bill Lalk in forum Shop Talk
    Last Post: 09-11-2010, 01:57 PM
  4. rear axle seal
    By 4play in forum Shop Talk
    Last Post: 08-30-2009, 09:02 PM
  5. HELP right rear axle seal...
    By rayjay in forum Shop Talk
    Last Post: 04-16-2008, 06:49 PM
