Results 1 to 6 of 6
Thread: EGR component help
    Oct 2024
    Virginia Beach, VA
    EGR component help
    Happy Saturday! Would anyone be willing to post or pm me some photos of the major EGR components and the lines? The previous owner of my marauder did some “bypassing/Frankensteining of the EGR valve and tubing. While this itself doesn’t really bother me, the check engine light does so I’m looking to put everything back as it should be. I’ve never messed with or paid much attention to emissions systems before wich is why I’m asking for the help.
    Thanks in advance!
    Oct 2020
    Chandler Arizona
    My car is not where I am, however, next week I can send photos. Should be Friday.
    '03 Silver Birch. Rebuilt 4.L 32V DOHC, V7-JT blower w/ADTR racing supercharger kit, Shift kit in transmission, stainless works long pipes and cat backs, Ridetech coil-overs front, shocks in back (ADTR kit). Rebuilt calipers, upgraded front rotors, OEM Mercury wheels, [boost, oil P, WB fuel/air, and fuel pressure] gauges. Build duration was Dec 2019 to Mar 2022. Upgraded to 8 rib belt to reduce slip, July-Nov '23. Car broke during tune with Marty Feb '24. Running again May '24. Still needs tune.
    Jun 2008
    Lompoc, Ca
    Here are a few pictures of mine when I was getting ready to do timing chain tensioners. I dont believe the engine had been taken apart prior to that so everything should be as from the factory.
    Good luck!
    Sounnder
    Oct 2024
    Virginia Beach, VA
    Thank you sounnder!! I really appreciate it!
    Nov 2024
    tokoyo
    The EGR system consists of key components like the EGR valve, metal tubing, vacuum lines, and the DPFE sensor, all of which work together to reduce emissions. If the previous owner bypassed or altered these parts, you’ll need to inspect and replace any missing or blocked components.
    Nov 2024
    Dalton, Ga
    Where is the DPFE sensor? Isn't it part of the EGR valve?
  1. UAC A/C Compressor & Component Kits
    By RockAuto in forum RockAuto
    Last Post: 04-29-2019, 07:39 AM
  2. component speakers or coaxial?
    By Davco in forum Interior Electrical/Electronics
    Last Post: 01-10-2016, 09:54 AM
  3. Component Identification
    By jwibbity in forum Shop Talk
    Last Post: 09-28-2015, 04:49 PM
  4. Infinity component speakers
    By Pops in forum Pops Stereo
    Last Post: 09-26-2008, 10:53 AM
