Results 1 to 15 of 16
Thread: Valvetrain noise
    Jul 2024
    Texas
    Valvetrain noise
    Stock 4v 4.6 has a ticking from the driver side and seems like valve train related. It’s loud enough you can hear it with the hood closed. Is this common or should get ready for a full teardown?
    Apr 2010
    South Florida
    Quote Originally Posted by 4Eyedturd View Post
    How many miles? Have You ever serviced the timing components?
    Jul 2024
    Texas
    Honestly not sure on mileage, previous owner swapped the motor 15k miles ago. I haven’t touched the motor yet.
    Apr 2010
    South Florida
    Swapped with a used engine? Reman? Usually the timing components are what makes noise on these.
    Jul 2024
    Texas
    Swapped in a used engine. The noise sounds like from valve cover but I guess I could start with timing components.
    May 2009
    Moreau Island
    Take a quick look to see if the manifold has a leak. Does the sound go away after the car warms up?
    Driver side? There is a poor cooling passage in head around cylinder 8 and it runs hotter and over time can cause build up and poor valve seating. There is a head cooling mod but it won't fix it if already bad. Compression check will tell you.
    Jul 2024
    Texas
    Noise is there warm or cold.
    Feb 2024
    Dallas
    If you haven't yet, address the timing chain components.
    Does the noise sound like this?
    https://www.youtube.com/watch?v=cbRDZKT7rxM
    Disregard the seafoam comment in the comments, in the facebook post that video was linked to the noise returned for that owner.
    I suspect that noise is the infamous "head tick" as there are a bunch of other posts on the facebook groups, same noise reported and shown in their videos.
    Jul 2024
    Texas
    I forgot I had a video of it from a while back.
    https://youtube.com/shorts/_Isla-Lux...ekVmxZ1kzrJSs0
    Feb 2024
    Dallas
    Sounds a lot like it if ruling out the timing chain component business. If you're on facebook PM your name I can send a bunch more posts with the same noise.
    You can also do a used oil analysis with Blackstone laboratories for excessive metals. Mine came back fine even with the tick/light knock.
    Jul 2024
    Texas
    That makes me feel a little better, I kind of assumed I had potential head damage.
    Feb 2024
    Dallas
    A lot of people will talk about burned valves or pistons for 7 and 8, worn out valve guides, etc. for the head tick/knock noise. Burned valves and pistons are going to misfire and run terribly rough. Worn valve guides will do the same + oil consumption usually. This noise is irritating to say the least. Some folk even rumored Ford had a TSB for it back in the day but could never verify that.
    Maybe its something like resonance in the head, a characteristic design of the valve train??? hard to say. Stranger still i've yet to find anyone actually report a legitimate repair or any real evidence of fault or excessive wear.
    In one of the posts I sent you on Facebook, one of the guys reporting the same noise replaced all the timing chain components AND every valve lash adjuster and the noise didn't change lol.
    May 2009
    Moreau Island
    Timing chain noise is usually a slapping sound on start-up that disappears after oil pressure builds up.
    Timing chain noise sounds like a sewing machine.
  1. Valvetrain noise?
    By klowpez in forum Shop Talk
    Last Post: 12-27-2022, 01:47 PM
  2. Ticking noise in valvetrain.
    By ByronRACE in forum Shop Talk
    Last Post: 09-26-2013, 02:42 PM
  3. Noise from LF
    By MJOR in forum Shop Talk
    Last Post: 12-08-2008, 09:14 PM
  4. Replies: 7
    Last Post: 06-02-2008, 08:09 AM
  5. valvetrain noise
    By PSG in forum Shop Talk
    Last Post: 09-15-2007, 02:35 PM
