Results 1 to 3 of 3
Thread: Things to do to junkyard replacement motor
    Jul 2024
    Texas
    Plans are to put in a junkyard 05 aviator motor that is of unknown condition and miles. Before I go thru the work of pulling the motor in the car and putting this one in what are something’s worth doing or checking? I figure at least timing chains, oil pan gasket, rear main seal. What about top end and bottom end?
    Sep 2005
    APPLE VALLEY,CA
    I have a replacement engine in a totaled marauder in my back yard.
    Problem is I don’t have the knowledge or expertise to remove it for my Black.
    It will need all these things before I put it in the black. 274000 miles and the oil pump failed. However it has an upgraded differential and the big brake package. The trans was rebuilt at 198000. This was my daily driver.
    Replace the oil pump also!!
    Oct 2008
    Toronto, ON
    There's a coolant tube that goes under the intake manifold.
    Rear cooling head mod.
    Exhaust manifold bolts/studs.
    Things to consider.
  1. Replies: 1
    Last Post: 05-31-2024, 02:46 PM
  2. Drivers Window Motor/Regulator Replacement
    By CKMustangCobra in forum Shop Talk
    Last Post: 05-21-2015, 09:36 PM
  3. Junkyard 31s?
    Last Post: 03-13-2011, 08:55 PM
  4. Wiper Motor Replacement
    By ctrlraven in forum Shop Talk
    Last Post: 04-26-2008, 07:55 PM
  5. Wiper arm removal for wiper motor replacement
    By mrjones in forum Shop Talk
    Last Post: 09-16-2007, 11:20 AM
