Results 1 to 4 of 4
Thread: Wrong Front bushing? correct P/N?
    Oct 2015
    SF bay area, CA
    My 03 Marauder needs the front lower control arm bushings (rear most)
    I ordered the correct K80833 and K80834 (as per Moog's website)
    But clearly, they are not the same. (Old right, new left)
    I went to my local ford dealer and they said its not available.
    Any advice on this one?
    Im a gearhead with way too many vehicles...
    Im here to talk about my 03 Marauder. 300A/B (I have a weird mix)
    165k miles as of dec 2018
    Jmod, removed 2 springs
    flomaster
    tint and 2din headunit + bigger sub
    Lehigh Valley, PA
    I mean, you're comparing an aftermarket Moog to an old OE, I am not surprised it isn't a carbon copy.
    PNs look correct as per rockauto
    2063/3214
    5377/7838
    Caledon Ontario, CANADA !!
    As long as the physical mounting dimensions are the same, that’s probably the closest you’ll get. Often the aftermarket part will look different but have similar functionality.
    03 Marauder
    12 GT500 coupe
    Looks like you need to try other suppliers to see if they're the same. Maybe a Chinese supplier will have the correct dimensions. The Moog part could possibly be modified to make the hole larger, it appears the OEM bolt size may not fit the new part.
  1. Front Lower Control Arm FRONT bushing moved after replacement
    By emott in forum Steering, Suspension & Brakes
    Last Post: 11-17-2014, 06:46 PM
  2. Poly front A-arm bushing
    By SpartaPerformance in forum Sparta Performance
    Last Post: 05-16-2011, 08:21 PM
  3. front suspension bushing kit?
    By 03calitejas in forum Steering, Suspension & Brakes
    Last Post: 09-12-2009, 03:37 PM
  4. Is this guy correct, or all wrong???
    Last Post: 02-20-2006, 12:11 PM
  5. Replies: 16
    Last Post: 07-31-2003, 08:17 PM
