Results 1 to 15 of 23
Thread: Starting issues car cranks but no start
    Jun 2021
    Florida
    Car cranks but doesn't start. Plugged in OBD2 and no codes show up. l pressed Schraeder valve on the fuel rail there is definitely fuel pressure.
    When crank is spinning the RPM gauge moves smoothly so I don't thinks its the crank sensor. I am thinking relays but wouldn't that show up on the OBD scanner?
    Can someone give me good input on this issue?
    Sep 2005
    APPLE VALLEY,CA
    Check the fuse that controls the alarm.
    I once had that fuse blown couldn’t figure it out until we replaced it
    Jun 2021
    Florida
    Ok I will look at that Thanks
    Jun 2021
    Florida
    Ok I will look at that .
    When you say alarm are you referring to the chiming noise when key is in the ignition?
    Thanks
    Jun 2021
    Florida
    Car is starting have not done any repairs. I got a hold of OBD tool and there is no codes, This is very vexing would like to know what caused the no start.
    Anybody have suggestions how to determine what the fault is ? I dont want to get stranded somewhere.
    Quote Originally Posted by blackcar View Post
    crank no start with no codes most likely is the fuel pump. Ever since we’ve been getting ethanol the decline of these pumps has increased quite a bit.
    You can put a fuel gauge with a 6 foot lead and put the gauge underneath your wiper and when that car don’t start you’ll notice you’ll have very little fuel pressure.
    I believe two of my dad‘s cars have required fuel pump replacements within the last two years, the fuel pump went out in my blue car about two years ago
    my DTR when it had about 52,000 miles the fuel pump would intermittently stop working when my buddy John owned the car. He went to the extent of putting a fuel pump driver, module and countless times to the dealer before we just replace the pump and that car is never had a single problem. It has 79,000 miles on it and it went bad. But my car was 210,000 miles got the original fuel pump in it and it’s working fine
    May 2019
    Harrisburg, NC
    When you get in your car and go to crank it, do you hear the fuel pump engage? Based on my personal experience, I don't think you'd get a no start/start situation with a bad fuel pump; when mine went out, it went w/o any warnings. But if it cranks that means it's getting spark and air, so that only leaves fuel not getting to where it needs to be...
    Jun 2021
    Florida
    Thanks guys Ill check on the fuel delivery system
    Sep 2005
    APPLE VALLEY,CA
    Did you move the shift level at all?
    It’s possible you weren’t fully in park so the car cranked, but wouldn’t start. It could be your range sensor.
    Happened to me in my Lincoln MKS last month . Unfortunately the range sensor is inside the transmission on the Lincoln $500 labor.
    The marauders range sensor is a five minute job under the car
    Jun 2021
    Florida
    Ok it happened again cranks no start and this time the scanner is showing codes
    P1237 & P0191. So it appears I have issue within fuel delivery system.
    I am going to check wiring first and then look at replacing components.
    Advice on P1237 & P0191 is welcome
    Jun 2021
    Florida
    According to the codes I just got its not this issue. Ill remember this info for future reference. Thanks BLACKMARAUDER04
    Jun 2021
    Florida
    Its definately a fuel related issue
    Jun 2021
    Florida
    Well... It appears its the the fuel pump. Ran power directly to it 12V 2 amps and nothing not a sound it's dead.
    Already ordered a Wix fuel filter what should I use for a fuel pump replacement?
    Sometimes they are so easy to diagnose. It’s looking you in the face.
    I believe you can just order a fuel pump and hanger assembly from O’Reillys, I know some people go with Aeromotive, walboro or stock.
    Jun 2021
    Florida
    Dont under stand why it did not immediately throw some codes at least I know what the issue is now.
    Bummer about your wrecked car.
  1. Marauder cranks but won't start
    By BLACKMARAUDER04 in forum Shop Talk
    Last Post: 05-23-2020, 09:10 AM
  2. Replies: 22
    Last Post: 04-07-2015, 09:25 PM
  3. Help! Engine cranks but wont start
    By GetMeMyStogie in forum Shop Talk
    Last Post: 04-02-2015, 05:46 AM
  4. Car won't start. Cranks but won't fire.
    By Steve in forum Shop Talk
    Last Post: 06-11-2012, 02:52 PM
  5. cranks but no start?
    By deathdealer9mm in forum Shop Talk
    Last Post: 07-21-2009, 02:56 PM
