The gas tank is in the same location for the CV, GM and MM. On the P71 CV, the car is being hit at speeds upto 120 mph. You can look at what happens to a CV being hit at 82 mph at this site:
www.firepanelllc.com/frameset.html
Yeah, don't forget, the P71's gas tanks is also alot larger than the civvie unit. Which makes for alot tighter quarters behind the rear axle.
Logan
Visit My Garage
The gas tanks for CV, GM and MM are all the same unit. 19 gallons gasoline.
Part of the issue was the shock mounts. That was supposely one of the fixes. If you notice now the 2003 panthers they are now moved to the outside. For better stability of course
2003 Marauder 300A
Kenny Brown Dead Pedal
Silencer Removed
K&N Air Filter
Amsoil Synthetic
What happens to a panther platform at 120 MPH?
THE SAME THING THAT HAPPENS TO ANY CAR AT 120MPH!!
Gone, but not forgotten
And your point is?Originally posted by V10_P70
The gas tank is in the same location for the CV, GM and MM. On the P71 CV, the car is being hit at speeds upto 120 mph. You can look at what happens to a CV being hit at 82 mph at this site:[/url]
I read the PI gas tank is 25 gallons.
Logan
Visit My Garage
Sorry Logan, I gotta step in here, because I still don't get something.
Be it one gallon of gas, or one hundred gallons of gas up my butt, the chief issue here is the overall safety of the Panther platform at high speed impact.
Like it's been said before, crush 2/3rds of any automobile into it's last 1/3rd, and something should blow. Blow up, blow out, or, become explosive, like from plain old compression hell, even water is explosive at a particular rate of compression...Damn the burn, what is the point here, anyway?
Yo...V10 something, you were saying?
By looking at the general stats the panther platform cars are quite safe. They confirm to the FMVSS safety standards and Ford goes above and beyond this to 50 mph test. With the car having the tank in the rear and the higher speeds the cars are run to, one would look to see what options exist for additional safety when the vehicles are driven hard. Meaning nine tenths of their capability.
A miltary fire suppression system that has existed for 30 years is available for this car to prevent the problem of fire in the car. We test at speeds up to 160 mph and look for all the safety features to insure that the driver walks from the car. This means brakes, driveshaft, springs, shocks, sway-bars, cooling systems need to be addressed. Just trying to pass on ideas that we use.
Here are the facts on the P71 Crown Victoria:
http://www.fleet.ford.com/products/s...nterceptor.asp
When two metals collide--the result will most likely be a spark--the faster they collide the quicker the spark--add a flammable to air mixture around it and you sure to have --BOOM!! It doesn't take a collision of high speed necessarily to cause this....a spark, a flammable mixture in air and the substance around it all to sustain it beyond the air mixture ,i.e. material to free burn after iginition---tires, cloth/leather seating/ material in vehicle.....all the same stuff in and around our daily lives every day ...just the right combo of physicis (without getting detail)--heat, fuel and air----BOOM!!! add the other and it continues to all is gone!!! p.s--water boils--turns to steam---that can also burn you!!!!!
12.45 at 109.6 MPH
1.92 Sec .- 60 '
Alt .SSHS 9 --11/7/09
'06 CV P71 Street Pkg
Interior Marauder Floor Shift
All New Parts
In Memoriam....11-14-13
Hey Guys,
As an insurance agent I can definitely say that the Marauder and all of its variants (Crown Victoria, Grand Marquis, etc.) are some of the safest cars on the road. But if you get hit by anything doing 120mph you’re going to have some issues.
Brian Fair
--2003 Mercury Marauder (300A)
Factory Spoiler
Pre-Production Tips
Reinhart Performance Chip
Plugs & Thermostat
4.10 Gears
K&N Filtercharger
no fire
This is also a good site http://www.cvpi.com
Member Number 32
Ahhh...now I get it. You're trying to sell us something we don't need.
Find me an exhaust system that will produce 20-25 HP over my present numbers, and I'll gladly share some coins with ya...
Thanks anyway, V10_P70
you know when pintos where catching fire when rear ended everybody blamed the tank location too.
I think all mid sized,and maybe most cars from mid 50's to about 73 all had fuel tanks that were part of the trunk floor or even behind the seat in trucks.The gas was RIGHT there!
The REAL problem with the Pinto was it's SIZE or lack of, that caused it big problems.Just about EVERYTHING on the road was MUCH bigger,so when it got hit,well it lost!
The Panther platform that is our Marauder excedes all federal crash test in place when it was produced.
Unless they add a "parked on side of the road and rear ended at 80mph test" I dont see much need to worry about how this car will hold up when slammed like that.
Unless you want to crawl over a NASCAR style roll cage evertime you jump in your car to go get a Big Gulp,oh after putting on your 3 layer suite,fire proff long undies,gloves and shoes and full face helmet,then buckeling up you 6 piont harness,I don't think your going to do much better.
I've said this before,when the subject comes up.
DON'T PARK ON THE SIDE OF THE HIGHWAY!
