Results 1 to 12 of 12
Thread: Will running a smaller diameter rear tire cause my speedometer to be off??
    Jul 2003
    Burbs of Chicago, IL
    I have started to weigh my options for snow tires this winter and I found a decent package that uses 235/60-16s all the way around. This tire size is pretty much the same diameter as the stock front 18" tires.
    I know people have talked about running fronts all the way around with no issue, but I want to make sure I am not screwing anything up by running a smaller tire at the rear.
    2012 Mustang GT500
    2001 Corvette Z06
    1992 Cadillac Brougham d'Elegance 5.7L
    Previous MMs:
    2003 Dark Blue Pearl/Charcoal
    2003 Black/Charcoal 300A
    Jul 2002
    Marietta, GA
    It will be off approximately 5MPH @ 70 MPH. Equivalent to 3.75 rear axle ratio vs. 3.55.
    Bill
    03 Mercury Marauder, 300A
    SOLD
    2005 Lincoln Town Car, ADTR Supercharger, TCE Brake Lines, MO's Tune
    2022 Lincoln Aviator Reserve AWD
    smaller rims are ok as long as you keep the overall tire height as close to stock as possible.
    Aug 2004
    Fairfield, PA
    Quote Originally Posted by ADE 1000
    Better make sure they're gonna clear the brake calipers.
    Aug 2003
    Philly
    Your speedometer, and odometer, would read higher than actual. However, you could have an even bigger problem with the anti-lock brakes if the difference in diameter from front to back is too great.
    ______________________________ _________________
    96 BBB Impala SS - Stock with bolt-ons 12.82 @ 106
    96 DGGM Impala SS - 496 BBC 10.13 @ 134 all natural, 9.69 @ 143 on the gun
    It'll work....I ran 16" marquis wheels with snows on all four corners the first year I had the car. As long as the circumfrence is the same all around, or even a tad taller in the rear, the ABS won't care. Now the traction control will however once over about 40 mph, but who cares, turn it off. With quality snow tires, one doesn't need the t/c anyhow.
    And yes, the speedo will be off, and the odo will rack up a few extra miles, but again, who cares? You'll figure out the speed your driving after awhile, and besides, it'll always read higher than which you are really traveling, so it also may avoid speeding tickets!
    On a dry day, you'll swear you had 4:10's installed, and start smoking people left and right.
    Happy wintering!
    2017 Niro
    Middletown, De.
    I run the smaller front tires on all four courners. Allows for better tire wear due to rotation. The speedometer/odometer will run about 3% FAST as verified via a GPS receiver. The ABS should not be that big of a problem, but if you have traction control, the smaller tires on the back wil cause the TC light to come on. Just turn the TC off and although the light will remain on, nothing else should be affected as you drive.
    Bob, USNavy Retired
    South Florida
    Blog Entries
    1
    What happeneds if you run the rear tires in front & rear. ?
    Jul 2003
    Thanks for the responses guys.
    I will probably still try to find a rear tire that is the same diameter as stock, but its good to know that I can run a smaller tire in the back without any major issues.
    2012 Mustang GT500
    2001 Corvette Z06
    Previous MMs:
    Jul 2003
    Quote Originally Posted by Cobra25
    There have been some posts discussing this lately and the consensus is that aside from some slight rubbing at full lock it should work fine.
    2012 Mustang GT500
    2001 Corvette Z06
    Previous MMs:
    Middletown, De.
    Again, if you have traction control, it will see the rotation differences from front and rear, and activiate the TC above 35 MPH. Again, just turn it off. Otherwise, what was said above about the slight rubbing......
    Bob, USNavy Retired
    Madison, WI
    Tire size calculator
    Hey:
    This is a great little Tire size calculator. You can use it to compare two sizes and it will tell you exactly what difference you see will in RPM and Speed.
    Hope this helps.
    Peter aka MMM2003
    300A Stock MM03 born on 6/25/2002 - sold June 2010!
    (owner from 8/26/2002 - June 2010)
    - Production# 2003 of 7838
    - @17000miles 1/4 in 15.1s@93.3mph
    - 180 TStat
    - 235/50/18 on all four corners
    - Dyno tune by SCT (Jerry W.) on 04-03-04
    @ 260.7 hp/285.5 ft-lbs
    - Front and rear EBC brakes with SS lines
    - PHP upper & lower rear control arms
    - Metco C/F intake tube
    - Infinity speakers
  1. Rear tire sale (TIRE RACK)
    By CRUZTAKER in forum Community Discussion
    Last Post: 07-12-2008, 02:54 PM
  2. Theoretical Max Rear Tire Width
    By Dan in forum Shop Talk
    Last Post: 09-14-2004, 06:52 PM
  3. Rear Tire Wear??
    By Marauderjack in forum Tires & Wheels
    Last Post: 05-23-2004, 05:25 PM
  4. rear spare tire
    By Kelly in forum Community Discussion
    Last Post: 10-26-2002, 02:02 PM
