Results 1 to 14 of 14
Thread: Remote Oil Filter ?
    Remote Oil Filter ?
    I'm going to install a remote oil filter sometime soon. I have the SVO unit from Ford Motorsports. It uses the FL1A filter on the remote mount. The FL1A does not have an anti-drainback valve like the stock one uses, but I believe that should be ok since the filter will be mounted in a vertical configuration that shouldn't drainback anyway. Agree or disagree? I do like the FL1A substitution in that it is larger and provides for more filtration surface area.
    Agreed.
    However...(you KNEW there'd be a "however"...)
    To prevent the lines to and from the remote filter from draining back requires mounting the remote filter at the same height or lower than the filter adapter on the block...
    Timbuk3, MI
    FordNut / RF Overlord
    Are you sure that the FL1A does not have the anti-drainback valving ?
    While that filter fits applications going back to 1957, my understanding was that the anti-drainback valving was SOP ( Standard Operating Procedure ) on all Motorcraft filters.
    Quote Originally Posted by gdmjoe
    Just repeating what the service tech told me. Maybe I should have done more research before posting? But since it will be mounted on the frame rail it should be below the OEM filter location so it won't matter in my case anyway.
    Timbuk3, MI
    According to Motorcraft ... yep it's ( drain-back valving ) in there. Link *Specifically mentions FL1A.
    Now who ya gonna believe ?
    Aug 2004
    Fairfield, PA
    We've been using 'em for a while, now, and think the last units were from Summit Racing. Make sure you use the teflon tape on the threads, as instructed, or I guarantee they'll leak. Also, check, and check again to be absolutely sure which are the inlet and outlet lines. You're going to be very pleased with the remote setup. BTW, we use AMSOIL filters exclusively.
    Texas
    Just FYI, the FL-400S is a direct bolt on (I didnt say replacement) fit as the FL-1A and has a SADV, this filter is used on V6 mustangs, V6 Econolines and Vulcan V6 Taurii....Might not have as much filter area as the FL-1A, but does have SADV.....
    have you considered using the Relcation kit from a 16V Pre 99 5.4L Navigator? it is located on teh inside of the bumper on the frame and uses an FL-820S
    '15 F250 CC 4WD 6.7L PSD
    '11 CVLX
    '05 E55 AMG
    '91 350SD Turbodiesel
    '97 Land Cruiser/78 Land Cruiser
    Quote Originally Posted by wchain
    I was wondering about this...I've used Motorcraft FL400S filters on my old Taurus V6 and the box SPECIFICALLY mentions that it has a 'Silicone Anti Drainback Valve'. The Motorcraft FL-1A box says nothing about the 'SADV'....???
    Does the FL-1A filter have the SADV??
    I'm not too worried about it because my remote oil filter set-up has the filter mounted vertically to hold all the oil in the filter.
    It appears that the FL-1A does indeed have an ADBV, but only the FL-820S and the FL-400S have a silicone ADBV...
    A silicone ADBV is not of any great concern on a remote filter application, unless you're going to run extended (over 5,000-mile) change intervals.
    Timbuk3, MI
    RF Overlord -It appears that the FL-1A does indeed have an ADBV, but only the FL-820S and the FL-400S have a silicone ADBV...
    Just curious but ... What's you source of information for the FL-1A not having a silicone ADBV ?
    Since Motorcraft says ( as per the link provided above ) ...
    Oil Filters
    Engineered specifically for Ford, Lincoln and Mercury vehicles, each Motorcraft® oil filter, including the popular Motorcraft® FL-1A, uses as many as 12 high-quality components. Construction features include:
    - Steel Cases
    "Ironed" for a precise fit, fluted to ease removal and painted for rust-resistance.
    - Pressure Relief Valve
    When it's cold outside or if the filter becomes clogged, oil flow through the filter can be reduced. If this happens, the relief valve opens to provide a continuous oil supply. Its design also minimizes the chance of contaminated oil recirculating back into the engine.
    - Anti-Drain Back Valve
    This feature keeps oil in the filter to prevent "dry starts" after your engine has been turned off. It's made with specially formulated material that resists the aging effects that an engine's heat can cause.
    - Efficient Filter Media
    Re-engineered media increases Motorcraft® filters' dirt-collecting capability, allowing them to capture more engine-harming particles than ever before.
    Texas
    Oil Filters
    - Steel Cases
    Doesnt Say silicone ....IIRC the "A" in FL-1A is for the ADV......
    '11 CVLX
    '05 E55 AMG
    gdmjoe, I got my info directly from the Motorcraft web site, right below the part you quoted, where it states:
    Silicone Valve Oil Filters
    Motorcraft® offers specially designed silicone components in the anti-drainback valves for oil filters FL-820S and FL-400S. The silicone valves retain flexibility throughout the life of the filter. This ensures better oil retention in the filter and faster engine start-up lubrication
    Timbuk3, MI
    FordNut
    Brian ... You've got mail! *via mercurymarauder.net's Email service.
    Jul 2003
    Orange County New York
    Cool Remote Oil Filter
    If and when possible would like part # and pics so as to try this when it gets a little warmer up here...
    I'll keep my Freedom, my Money, my Religion, my Guns & you can keep the " Change ".
  1. Engine Oil Cooler with a Chasis Mounted 1Qt Oil Filter
    By 03SILVERSTREAK in forum Community Discussion
    Last Post: 06-22-2004, 04:44 AM
  2. Oil Filter
    By 2003DOHC in forum Shop Talk
    Last Post: 05-15-2004, 06:01 PM
  3. How do I get this oil filter off?
    By LNYTUNS in forum Shop Talk
    Last Post: 03-03-2004, 08:50 AM
  4. Oil Change instructions
    By TripleTransAm in forum The Lounge
    Last Post: 01-04-2004, 04:17 PM
  5. Mobil 1 - OK?
