Those with Marauder spoilers, I know you were breaking your own heart drilling those little holes to put the spoiler on, but here's an idea some of you may or may not like about third brake light.
I've been looking on the install pix of the spoiler on a Silver Vic and there is definitely a void in space.... a missing piece in that opening around the ford logo on the trunk so I figured the best way to fill it is by use of an exterior third brake light.
I'm not sure which one out there would fit the hole best, (haven't researched the designs yet) probably something slim and short similar to those on Impalas (well impala's is a little too long) or something, need to do more research.
Once the third brake light would be moved onto the trunk from the rear dash, what would you guys fill the hole with on the rear dash once that piece is out? Is there like a piece of some audio/stereo equipment that you can put on the rear dash by the window and it will improve the sound quality of your system, or what? I mean the hole is already there, maybe a sub can fit or a couple of tweeters?
I'm just contemplating this idea for my Vic when it gets a spoiler. I've done some drilling in my previous trunks like my first 1992 got a spoiler, and on my 1996 I did a Ford oval mod where I took an opening keyhole ford oval from a 1991 Vic and put it over the keyhole on my Vic, it was awesome, here's a pic:
there really is nothing to it, Vic trunks are made of slim metal that can be cut/drilled thru easily.
What do you guys think?
--Russ
