Originally Posted by
RF Overlord
BTW, it's only the oil pressure gauge that's fake...the OEM voltmeter does actually work, but replacing it with the aftermarket AutoMeter version keeps the two gauges matched...and it's only $35 from Summit...
The OEM Volmeter is not accurate at all.
It can read anywhere from 1 - 1.5 volts LESS than what the actual charging system is producing.
You are better off replacing BOTH of them.
It is so easy to do.
Pete...
DOB 10/31/2003
DOP 1/2/2004
DOB 12/11/2018
DOP 6/19/2019
