Results 1 to 7 of 7
Thread: air suspension adjustment help
    Quebec city Canada
    Hi,
    I saw on a previous tread that it's possible to lower the rear suspension by sliding the bracket attached to the tracking arm.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o:p></o:p>
    <o:p></o:p>
    I proceeded as specified by the procedure, meaning, loosing the nuts of the bracket and sliding it IN THE DIRECTION OF THE PASSENGER SIDE (to lower the car).<o:p></o:p>
    <o:p></o:p>
    Unfortunatly, the car raised up about 3/4 of an inch. Since i forget to put the trunk switch at off, i decided to wait 2-3 days for the suspension to settle but it didn't move from it's new position.<o:p></o:p>
    <o:p></o:p>
    Before i fool around again (!). i would have a question:<o:p></o:p>
    Is it possible that that the bracket must be slided IN THE DIRECTION OF THE DRIVER to effectively lower the car ? (I understand, giving the results, this would seem obvious but, looking at the underside bracketry, the logic seem to be pointing to sliding the bracket toward the passenger side).
    <o:p></o:p>
    Thanks for your consideration. Regards
    May 2003
    Waterloo, IA
    The bracket needs to slide towards the drivers door to lower the rear.
    Cheers!
    John
    MARAUDER S/C #5 Guest
    So the instructions in post #4 of this thread:
    http://www.mercurymarauder.net/forums/showthread.php?t=1089&highligh t=height+adjustment
    ...........are WRONG !
    No wonder my car didn't look lower.
    Quote Originally Posted by MARAUDER S/C #5
    I just updated it to correct the instructions. I corrected another thread that referenced this one awhile back but forgot about this one. Sorry 'bout that, folks!
    May 2003
    Waterloo, IA
    And after reading the info in that link, it mentioned using a 7/16 socket. That's a no-no. Everything on the Marauder is Metric. IF I remember correctly, I think it requires an 11 mm and a 7 mm socket to loosen TWO adjustment nuts.
    John
    Aug 2003
    Affordable Detroit
    Quote Originally Posted by TooManyFords
    John
    That's a metric 7/16.
    Dan
    Quebec city Canada
    Air suspension adjustment help
    When it comes to back ends, we all know that height does matter. Thanks you all for solving this little mystery.
  1. Air Suspension squeaks from Hell
    By Svashtar in forum Community Discussion
    Last Post: 08-23-2008, 07:49 PM
  2. Air suspension adjustment??
    By TechHeavy in forum Community Discussion
    Last Post: 11-23-2004, 05:28 PM
  3. air suspension/ ride height
    By NOTMYBOAT in forum Community Discussion
    Last Post: 08-02-2004, 05:18 PM
  4. Is there a way to "level" the air suspension?
    By studio460 in forum Community Discussion
    Last Post: 05-24-2004, 07:11 AM
  5. air suspension
    Last Post: 01-03-2003, 10:02 AM
