Results 1 to 8 of 8
Thread: Voltmeter low point?
    twolow Guest
    This is most likely a stupid or hashed out question but I really do look before I post
    I just got my over the hill MM with over 60K miles so when I see the voltmeter dance around at night I start worrying about a alternator. No modded pullies (as far as I know anyway).
    When I'm at a red light at night with the headlights on, taillights all lit up, etc the voltmeter likes to work its way down to 11-12 volts. The dashlights and gauge lights like to flicker a bit when this happens as well. If I let off the brake it tends to jump up some then of course jumps up to 13 or better once the gas is punched.
    I would think I'm safe unless its under 10 volts. True?
    Quote Originally Posted by twolow
    Sounds like 2 separate issues.
    The battry voltage is probably ok.
    The flickering lights have been mentioned here before, if the lights are dimmed with the switch, it is more obvious. With them at ful brightness is is less apparent, at least according to what I remember from previous threads.
    Apr 2005
    Queens NY
    My Marauder with 25k miles did the same exact thing with the voltage. I never had a prob with starting or running accesories so Dont worry about it too much
    Bay City, Michigan
    I'm noticing the same with mine and it has less than 5,000 miles. I think it's because of the low idle speed.
    2004 DTR Marauder
    Light Flint Interior
    Heated Seats
    Factory Moonroof
    SS Inserts, 6 Disc Changer, Trunk Org., Declikd Designs Decklid Liner, Spoiler
    2005 Ford Escape V-6
    1966 Mustang coupe 351 Cleveland 4bbl
    --Charlie Reinhardt
    V.P. Mustang Club of Mid-Michigan (06-08)
    twolow Guest
    Thanks for the answers guys. I thought it was normal but wanted to make sure
    MMSuperFan Guest
    I had flickering and low voltage with mine. The car came with one of the alternators with the clutch style pulley. I went to my local Ford dealer and purchased a Police interceptor alternator with the solid pulley. The PI alternator has a lot more amps than the stock alternator and the flickering stopped and the voltage reads much higher now. Voltage was a little more of an issue for me, since I had installed the Meziere electric water pump.
    Been very happy with the alternator upgrade.
    Long Island, NY
    Quote Originally Posted by MMSuperFan
    Is the interceptor alternator a direct replacement, with no modifications? Ie wireharness and mounts.
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    Mercury All Weather Mats
    1973 Oldsmobile Toronado
    2012 Kia Sedona Van
    2008 Corvette Convertible
    2021 Prius Prime Limited
    Member # 440
    ----- John
    MMSuperFan Guest
    Quote Originally Posted by jgc61sr2002
    It has been about a year ago that I did the mod, but, if memory serves me correctly, it is an exact replacement. You just install the new alternator on your bracket and the wiring was not changed.
  1. low Washer fluid sensor
    Last Post: 12-29-2004, 05:39 AM
  2. SCT 9100 update fixed low voltage at idle
    By MMSuperFan in forum Reinhart Automotive
    Last Post: 09-02-2004, 02:44 PM
  3. Worrisome voltmeter
    By Donald in forum Shop Talk
    Last Post: 07-23-2004, 08:41 AM
  4. 2 quarts low on first 4,100 miles
    By dansenander in forum Shop Talk
    Last Post: 07-22-2004, 04:13 PM
  5. Very Bright Low Beams
    By Cordoba1 in forum Community Discussion
    Last Post: 07-20-2004, 06:11 AM
