Radio Reception Not Working
Unfortunatley the reception is so bad the radio mostly emits static. Intermittenly voices will come thru.
CD works fine.
AM shows it is coming in as stereo. Checked antennae by unplugging it from the back of unit and the static went to no sound at all.
Any ideas, I assume the tuner is bad?
