Page 1 of 6 123456 LastLast
Results 1 to 15 of 76
Thread: Interest in PHP Cold Air Kit
    Paul, quit making the PHP cold air kit for the Marauder, I bought every kit he had, and I have sold every one, I like this kit I like the looks of it and the power gains I got from it, now there are several other kits available, I have not tried them, because as I said I like to looks and fit of Paul's, you the members can look at these kits if you so desire, I am not here to start a cold air kit war, and if it starts to turn into one I will just let this go and delete the post. Now if there are enough interest in this PHP kit I will buy these in bulk this is very hard to do for a small business, but I will do this for the club if there is enough to justify this type of investment, here is a picture of it and I will post the dyno links before and after, this kit just like the other two can be used with the Trilogy SC as well.
    I used my N/A Marauder, and I did a base run of 249.4 RWHP and 261.3 RWT
    http://web.iwebcenters.com/reinharta...kitbaserun.jpg
    Next I installed Pauls kit. I made no timing or AF Corrections, with the install of the kit the car gained 6.8 RWHP and 8.5 RWT Now look at the AF Below.
    http://web.iwebcenters.com/reinharta...aulsairkit.jpg
    What happened is with Pauls kit the AF went richer by about 8% this is caused by a slight change in the air meter transfer function, this is no big deal so I leaned the car out by 8% added NO timing and the car gained, 12.3 RWHP and 15.7 RWT
    http://web.iwebcenters.com/reinharta...fcorection.jpg
    So the kit does work and make a good power,
    Chicago
    a few of us have installed this airbox and i cannot recall anything other than excellent results and everyone i know that has installed this product has been thrilled with it.
    I highly recommend this product.
    Kudos for Dennis for picking up the ball on this.
    Here are some better pictures of the PHP kit. This stainless steel cover with some metal Polish really looks sharp of course its been a day or two since I last did mine.
    Here is the JLT kit
    And here is the K&N
    Florida
    I bought my PHP air box directly from Dennis, installed at his shop and documented with before and after dyno runs. Peak results are modest, results under the curve are huge, specially torque. I highly recommended.Dyno_Results
    Smokie
    12.79 @ 107 mph.
    TIMESLIPS
    Visit my Garage
    Dennis, I posted a "WANTED" ad in the classifieds for a PHP kit, but received no responses....I am DEFINITELY interested in a PHP kit!!!
    Chicago
    i went a step further and had the airbox laser engraved with the godshead logo.
    I have this kit,.. I love it!
    Will it?
    Will it work with the ProCharger?
    18psi pulley
    Billet Oil Pump
    ARP Bolts and head studs
    Snow Methanol Injection
    3500 Stall Converter (PI)
    Stryker 340 Fuel Pump
    45 lbs Injectors
    4:10 gears
    K&N Air Filter
    Factory Spoiler
    Widened Wheels
    Nittos
    170 deg thermostat
    SS Inserts
    Trunk organizer
    Jun 2004
    I totally agree, very well made and was the only choice when I purchased mine.
    Warson Woods, Missouri
    php air kit
    Ditto on Tom's comment. I have one but I have no idea what the K&N air filter part number is. Anyone know????
    Quote Originally Posted by Petrograde
    Dec 2003
    New York, USA
    Quote Originally Posted by BUCKWHEAT
    K&N AirCharger ( Part # 63-1111)
    K&N DryCharger (Air FIlter Wrap)
    RF-1041D(X) X = Color...
    K = BLACK
    L = BLUE
    R = RED
    Y = YELLOW
    So RF-104DK = BLACK DRYCHARGER
    Pete...
    DOB 10/31/2003
    DOP 1/2/2004
    DOB 12/11/2018
    DOP 6/19/2019
    Quebec city Canada
    Quote Originally Posted by Mike Mielnicki
    It won't. I had to take it off.
    Quebec city Canada
    I put mine on sale in the classified a week ago but somebody is interested. If he change is mind, i'll PM you.
    Apr 2005
    Plainview, NY
    do you need computer tuning after installing it, or will ti work fine without tuning on a stock 04
    Any time you change the induction system on most cars there is a chance of changing the Mas air flow transfer function, in the PHP case it can make the car rich but not by much, about 8% this can easily be fixed if this is the case. No matter who's CAK you use there can be these issues
    I like the PHP kit what I may try to do is make a complete kit from Throttle body to the PHP CAK, again this is a substantial investment, and its going to be dependent on demand, what you have to understand is to buy any thing at a reasonable price means you have to buy in quantify, so I can make a reasonable profit, without having to have a very high price on this product, so again I am looking at starting this but its going to depend on the interest here.
  1. Vortech Air To Air kit is complete - Restarted Thread.
    Last Post: 09-25-2005, 07:27 PM
  2. Vortech Air To Air kit is complete
    By Dennis Reinhart in forum Power Adders
    Last Post: 05-04-2005, 03:39 PM
  3. Vortech Air to Air kit update
    Last Post: 02-26-2005, 08:21 AM
  4. Cold air Kit arrives!
    By Bradley G in forum JLT Performance
    Last Post: 01-14-2005, 12:00 PM
  5. Air filters
    By Marauder04 in forum Shop Talk
    Last Post: 08-15-2004, 07:56 PM
