Originally Posted by
Defyant
"The third Saturday of every month will be the CAM meet."
Sounds good to me.....
Defyant
This will eliminate the 2 pages of "when" and make planning much easier. Where is to be determined.
Yeah, but we will STILL have 2 pages of "where".....
