Has anyone used 4 tires with the same diameter? Wanted to get some feedback on any possible ABS problems. If any problems was there a fix. Thanks for a graet site and any help.
I used 235-60-16 all the way around thru winter......no problems what so ever.
SLIGHT speedo issue, but if you have the RPC installed, I am sure it can be programmed accordingly...right guys?
2017 Niro
I'd tried 225/60-16 on all four but didn't work because of the traction control. Use(d) 235/70-16 out back for the winter.
03 MM
88 F250 460/ZF 5 sp 4x4
78 MKV 460/C6
77 LTD II
77 Cougar
77 Ranchero under construction 8 yrs and counting
This is good to know. I plan on running 235/50-18 all around when I get my 300a packaged MM.
(#6178 in black per FPIC)
Rest In Peace:
Paula Babineau 1/9/67-8/2/11
Rex Weinbender
Peter
Tetsu has been pursuing the "same size all around" plan for some time. Perhaps he will hit this thread and give his .o2 as well.
Economically, this would be a better scenario. Performance? Well, that's we all are still feeling out. Litterally. I wish my father was still alive, as an engineer with bridgestone/firestone, he frequently brought home prototype tires. We havn't paid for tires in 40 years in my family.
2017 Niro
CRUZ,
Hook me up! I don't live that far...
The different tire sizes do have a major effect on traction control functions. Continental-Teves of Germany-manufacturers of the traction control-use the ABS sensors, it computes the difference in the rotational speed between the front (non-driven wheel) and the rear (driven wheel ) on each side--when the driven wheels exceed a set % difference , the control brakes the fast wheel and then, if the difference increases, reduces power. I have more info
2003 MM 300B Black
Born 11/12/02 Adopted 3/29/03
"SHADOW"
Hood Ornament
Cruzer, do you think a MM with only ABS would encounter any problems? It sounds like the traction control is a bigger issue than the ABS . Any info you have on this would be a great help.
MM03:Originally posted by MM03
All of us snowbirds that run snows run all the same size tires in this setup. As I posted before, and all others above have said....
NOOOOOOOOOOOOO
This is first hand, so pitch the foreign reports and files and hear the real deal.
2017 Niro
Cruztaker,What foreign reports? North of the border you mean? First of 300a's are lacking TC so you will never know how it will react first hand with different tire sizes. And secondly that means you're drive a foreign made car!
03 MM
78 MKV 460/C6
77 LTD II
77 Cougar
There is always the potion of turning the TC "OFF." If you want to use the same size tires all around in a winter package, turn it off. Simple solution to a simple problem.
Bob, USNavy Retired
Thanks for the replys on this subject. All the owners with the winter tire set up got to do the testing.Sounds like there were alot of those out there this winter.
2017 Niro
Hmmm but a US market 300A isn't the same as a Canadian market 300A, so even more confusionOriginally posted by ron460
