Why it happens
This is caused by oxidation build-up on the dimmer switch contacts. There is a low voltage across the thumbwheel switch that the module reads and adjusts the light output accordingly. There isn't enough voltage to overcome the oxidation layer & therefore the resistance varies across the switch. So, when you rotate the thumbwheel you rub off the oxidation and get a constant resistance until the oxidation builds up again.
Ford eliminated gold contacts for the cost savings in many switches and contacts that were put in place to prevent these problems.
2003 300B BLUE (stolen for 9 days)
PI 3000 TC, 4:10 gear + girdle, Dynotech Driveshaft,
bulletproof trans, 2nd trans cooler + deep pan & Redline D4 ATF
Steeda UDs, Rear engine cooling kit, Denso plugs, high capacity oil filter on frame, Reinhart superchip
+ gauges, SilverStars, & fire extinguisher
2008 GMC Envoy SLT
2006 GMC 2500HD Crew Cab/8' Bed; 21.5' long
