Results 1 to 5 of 5
Thread: Oil Preasure gauge Conversion Photos
    Jan 2005
    Just South of Memphis, TN
    Question Oil Preasure gauge Conversion Photos
    I've looked and searched, but I can't find the photos in the Gallery that go with "vegasmarauder"'s oil preasure gauge conversion...
    Can someone please direct me to them...
    or...if they are now gone does anyone have a copy they might email to me....
    Thanks in advance for you time and attention....thanks, architect
    "Ford Racing" 410 gear
    18"X8.5" Black Bullitt Wheels
    "Ford Racing" Center caps
    Black Wilwood Brakes (fronts)
    "Powered By Ford" coil covers
    30% Window Tint
    "X-pel" Light Shields
    "Pro-gard" skid plate
    Rear Spoiler
    "Kenny Brown" dead pedal
    "Megs" delete resonator tips
    "SS" Titanium Inserts
    Blacked out window trim
    Cape Cod
    http://www.mercurymarauder.net/revie.../cat/12/page/1
    Reviews >>Interior >> Upholstery or Panel Products >> Autometer Real Oil Pressure Gauge
    MOK
    I don't brake for curves!
    Jan 2006
    Montgomery County, MD.
    Thumbs down no pic's
    I did the swap this past weekend... I followed the swap the guts on the new gauge as well as the terminal end swap on the sending unit written by vegasmarauder.. No real problems, works great other than I misplaced the needle so I am off by about 20 psi.. Be SURE to plug in the new sending unit prior to installing the needle. I used the old sending unit for power to calibrate the zero setting and was off. I will fix it this weekend. Looks great and it is nice to see the gauge move with rpms and temp... Good luck with the swap.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o:p></o:p>
    regards,
    ~mike
    2K4 DTR
    Trilogy #160
    some other lil' stuff.....
    Jan 2005
    Thumbs down Thanks for the response
    Quote Originally Posted by MM03MOK
    Thanks that's just what I needed....
    architect
    30% Window Tint
    Rear Spoiler
    Nov 2003
    Horntown, VA
    Quote Originally Posted by shami02
    ... Be SURE to plug in the new sending unit prior to installing the needle. I used the old sending unit for power to calibrate the zero setting and was off. I will fix it this weekend. Looks great and it is nice to see the gauge move with rpms and temp... Good luck with the swap.fficeffice" />></O>
    Would not have thought of that.
    Good tip - Thanks!
    Plate - "EVILMERC"
  1. Oil Pressure Gauge Conversion Part 1 of 2
    Last Post: 09-09-2019, 01:38 PM
  2. Fake Oil Pressure Gauge Question.
    Last Post: 08-22-2010, 12:21 AM
  3. RoyalPurple Synthetic 5w20
    By tetsu in forum Community Discussion
    Last Post: 04-18-2004, 02:31 PM
  4. Mobil 1 - OK?
  5. oil gauge
    By Wags in forum Community Discussion
    Last Post: 10-20-2002, 09:09 AM
