Results 1 to 10 of 10
Thread: RIP stock audio system
    Apr 2003
    5865 of 7839
    Hey -
    My radio and CD died this morning. All I get is some very quiet bass rumbling in the form of what I must have been trying to listen to, but can't tell for sure.
    Could this be a loose connection after 56K miles, or has this happened to anyone else?
    I'm kinda hoping it died so I can replace it with something that will handle mp3s.
    Ideas?
    Thanks
    -A
    Self-importance is our greatest enemy. Think about it - what weakens us is feeling offended by the deeds and misdeeds of our fellowmen. Our self-importance requires that we spend most of our lives offended by someone. -- Carlos Castaneda
    Jan 2006
    Central Ohio
    I hate saying this, but do a SEARCH. I think this has been discussed before.
    KillJoy
    Apr 2003
    5865 of 7839
    Um, did that already...
    Nothing. If it's out there it's hiding in a thread that does not have the following search terms.
    head unit
    stereo
    replace radio
    any version of radio or sound dead, dying, kaput, etc..
    There's tons of stuff on poor reception and ELECTIVE radio/stereo replacement, but nothing I can find on my particular problem.
    Apr 2005
    The Pitt, PA
    I got a factory radio for sale if you want it.
    2013 Ford Taurus SHO
    #1649
    boi
    Winnipeg,Mb.
    Someone mentioned wiggling a wire harness under the dash on the passenger side and it cured some sort of lack of sound. Could be a loose connector.
    -Mike
    #6018 of 11,052
    Trilogy #196 - Self-installed
    Stuff done to it. See here.
    Oct 2003
    Beaufort, SC
    They for some reason lose the frequency lock circuit and sound like a distant station...Mine did just that and Ford fixed it under warranty!! If you call the dealer he will order one that has been rebuilt and take yours as a core....takes about 5 minutes to swap them out!!
    If you need one I have a new one at a reasonable price....New ones are $500+??
    Marauderjack
    Apr 2003
    5865 of 7839
    I'm out of original warranty and I have a $100 deductible on my current 100K warranty. In other words, I'm not using the warranty unless it's something over $100. For this if I'm going to spend $100 I might as well spend $200 and get an aftermarket unit of some sort that's better.
    Maybe speakers, too.
    And a S/C.
    Hmm.
    I believe there is a diagnostic mode you can enter by pressing and holding 3 and 6 at the same time. Sometimes it will help if the head unit has just lost its mind.
    Off-Shore America
    If you need one I have a new one at a reasonable price....New ones are $500+?? Marauderjack
    Indeed. Exactly what happened to my #3 MM just after I brought it home. As the radio warms up, the stations/CD play fade to black. No CD play, head unit or trunk. You're right on the fix too. 5 minutes, 125 bucks + core radio. My replacement was refurbed by Alpine, according to the packaging.
    One other thing popped up while I was exploring my options, the Marauder head unit appears specific to the Marauder, at least as far as I could tell. Refurbs (if you can find them) go for 250-275 on e-bay. Here's some numbers that may help narrow the search.
    Ford part number is...3W3T-18C868-AA
    This may be the Alpine part number...KAH2XK482
    This label looks like a build date...2002.AP.May
    There are also two bar code lables which are not identified, and I have no clue what they mean. U9FR98BH20514287 and USURRS301831
    The Marauder radio differs from other Ford radios by the rear connectors, in-dash mounting (no rear support used) and dash panel light color.
    Hope this helps, carry on gents.
    Apr 2003
    5865 of 7839
    I'll have to drop by the dealer and check this out. thanks!
  1. Stock 8-Rib Conversion kit?
    By TooManyFords in forum Shop Talk
    Last Post: 07-07-2014, 12:15 PM
  2. Reinhart or Kooks exhaust system?
    By tmac1337 in forum Exhaust
    Last Post: 02-18-2004, 07:46 PM
  3. Question about stock exhaust:
    By BillyGman in forum Exhaust
    Last Post: 10-24-2003, 07:19 PM
  4. MM audio replace
    By Donald in forum Community Discussion
    Last Post: 03-04-2003, 07:59 PM
