I need some advice on what cam I should have used on my 85 GT when I rebuilt it. This is what went into it:
-BRAND NEW MOTORSPORT 5.OL 302ci ENGINE BLOCK (Explorer Block)
-MOTORSPORT GT-40P HEADS
-FEDERAL MOGUL SPEED PRO HYPEREUTECTIC PISTONS
-MOTORSPORT E-303 CAM
-MOTORSPORT 1.6 ROLLER ROCKERS
-MELLING HIGH FLOW OIL PUMP
-EDELBROCK PERFORMER RPM INTAKE MANIFOLD
-MOTORSPORT GT-40P HEADERS
-MOTORSPORT HIGH FLOW WATER PUMP
-HOLLY STREET AVENGER 670CFM CARBURATOR
-MSD IGNITION, DISTRIBUTOR, COIL, AND TACH ADAPTOR
-MOTORSPORT BLUE HIGH PERFORMANCE PLUG WIRES
-MOTORSPORT "MUSTANG" VALVE COVERS
-MOTORSPORT "MUSTANG" AIR CLEANER ASSEMBLY
-K&N AIR FILTER
-ARP BOLTS THROUGHOUT
-MOTORSPORT MINI STARTER
-SECONDARY OIL AND TRANS FLUID COOLERS
-MALLORY ELECTRIC FUEL PUMP/TANK PICKUP
-ENERGY SUSPENSION ENGINE/TRANS MOUNTS
-B&M TORQUE CONVERTER
-COMPLETE OFF ROAD FLOWMASTER EXHAUST SYSTEM
This is all married up to an automatic trans, AODE with a mild shift kit. I was told that E-303 is a mild cam and would work well with the AODE trans. But I also was told to I should run the X-303 cam instead. The motor was built with the E-303 cam, but I have a brand new in the box Motorsport X-303 cam sitting on my parts shelf. With the setup in the Mustang, what cam of the two would you choose and why. Should I swap them out? I listed the cam specs from the Motorsport catalouge if it helps. Thanks in advance.
Dave
