Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: Blinking o/d light and battery light
    Aug 2005
    San Antonio, Tx
    Exclamation Blinking o/d light and battery light
    Please.....Ok here is the situation: I get off of work at 3 P.M. and usually remote start the car to cool it down (we hit 100 yesterday), So it sits in idle for about 10 minutes and then it timed out and turned off, then I started it as I was walking to the car and forgot to put the key in and stepped on the break so it turned off, this time I started it with the key. No problems yet.
    I go to pick up some boxes here from work and the car sits idling for about another 10 minutes. So I load up 7 empty boxes an head for home which is a three mile trip. I have a total of 3 turns, one to leave work to the main street, one to turn onto my street and the last to turn in to home. I stop at 2 traffic lights on the way only about 30 seconds each.
    I use the o/d button once as I go down a hill to slow and rev as I go down the hill from about 55 mph, then I click it again to go to normal opperation. Maybe about 10-15 seconds use of the button. Well another mile and a half down the road the problem starts...I feel a little rough shift as I am slowing down from about 35 to about 10-15 mph and I look down and see the o/d light blinking and the battery light came on. I look and all my other gauges and all seem to be in the norm. Oil pressure ok, Volts about 12, water temp in the middle. The only other problem was that the car seemed as if was about to stall out but as soon as I stepped on the gas to go thru traffic it went.
    As I turned in to my apt complex it seemed a little juttery...then the lights went off and then nothing else happened....I backed in to my parking spot as I normally do....nothing unsual happing....shifted fine. I then let the car Idle as I made a quick call the the dealership and left a message for my service writer. I checked battery connections, oil level, trans level, the tensioner pully was moving side to side abit but no noises or anything else unusual was noted.
    I then turned off the car and did not drive it till this morning. The service writer called back that evening and asked me about it I told him the story above and said if I had anymore problems with it to bring it in after work. When I drove it this morning I had no problems with it. I made my usual stop at the local stop and rob and restared it and made my way to work and no problems.
    I tried to be as thorough as I could with all the info I had so I hope some one could tell me something...I do have about 5100 miles left in my 3yr/36k warranty. I have had the car since new, and I currently have no mods on it.....did have JLT on it before 30k check up. No other mods have been on this car performance wise.
    Thanks, Mike
    MM.NET Member #3943
    11/24/04 -'04 Silver Birch , Moon Roof, charcoal Interior,
    12/25/05 - Lower grill Mod - Thanks DEFYANT, 12/29/05 - OEM Spoiler - blankenship aero
    01/06/06 - Vynal Shades - Executive Signs Ltd., 01/06/06 - Silver Stars - MM.net (thanks everyone)
    01/11/06 - Remote start alarm ( North Park Linc. Merc. ), 02/16/06 - Pro Gurard - Reinhart Automotive
    02/24/06 - JLT CAI/RAI - JLT Performance(Jay Tucker), 06/14/06 - Godshead logo locking valve caps (Wes)
    02/14/07 - XCAL2 tuned by Lidio
    VEHICLES AND MILAGE :
    04 MARAUDER: 95,XXX (June 09) SOLD 1-28-14
    03 IMPALA: 126,XXX (June 09), Died Oct '11 143K
    01 SUBURBAN: 87,XXX (June 09) Traded in 9-22-12 123K
    07 SUBURBAN LT 4X4 84,XXX (Sept. '12)
    07 INFINITI G35 79,997 (Dec. '11) Her Ride!
    Off-Shore America
    Sound to me like you were running a tad warm.
    Our engines have to reach about 240 degrees before the dash needle moves, and then, it moves fast. The tranny will misbeave from high temps before 240, you may have gotten an early warning sign. BTW, flashing OD light is an indicator in code.
    Aug 2005
    San Antonio, Tx
    so will the code stay so that I can take it to the dealership and they can read it.
    MM.NET Member #3943
    Off-Shore America
    Maybe. Codes don't stick until the problem is chronic.
    Jan 2005
    The Otherside of the tracks
    True true, there are, as told to me, hard codes and soft codes. I had the same thing happen in my F-150. OD light blinked for a little bit but went out. At the time of the blinking the trans shifted funny and would not engage OD. Let it rest and problem went away and OD didn't come on but i wanted it checked anyhow. Though the light wasn't on, the code was stored in the PCM. Found out it was the VSS gear on the pumpkin. Changed it and everything was back to normal.
    '04 MARAUDER
    Born on 4/20/04 -- Foster Care on 5/11/04 -- Adopted on 01/27/05
    Heated Seats 6 Disc CD Changer Moonroof
    JLT CAI--Silverstars Heads/Fogs--SCT-9100
    SB IX - SB X - SB XIII - SB XIV - SB XL - SB XLIII
    Trilogy S/C In Due Time
    Aug 2005
    San Antonio, Tx
    well I guess what happens
    MM.NET Member #3943
    Brampton Ont
    Voltage dropped to low and set a code in the trans/controller.
    There are low voltage codes.
    probably from so much idling..probably just a querk..just keep an eye
    on the alt voltage--the alt may be showing signs of a problem!
    Monitor it!
    Apr 2005
    The Pitt, PA
    I second the notion of low voltage. Check static battery voltage after a highway drive. It should hold no less than 12.6 without the engine running. 13.5 at about 1.5K RPM. Don't trust the stock autometer guage. Mine is wrong. Our alts don't put out the 13.5 at idle. Excessive idling could be the issue.
    Hope that's all it is.....
    2013 Ford Taurus SHO
    #1649
    boi
    Quote Originally Posted by SID210SA
    ...I can take it to the dealership and they can read it.
    Yes, the dealer will be happy to read it for you and give you a whopping bill for "diagnostic time" as well, even if they find zilch. Take it to any AutoZone...they will read the codes (if any) for free. Then report back here and we'll tell you what's indicated...
    Jan 2005
    From my understanding the code readers that Autozone has will not read trans codes. Try a trans shop. They can read them. That's where I had my trans code read. They usually have the big Startech(sp?) code readers that the dealers and the factories carry.
    '04 MARAUDER
    Brampton Ont
    Quote Originally Posted by STLR FN
    This is true...
    Aug 2005
    San Antonio, Tx
    well wish me luck and I will report back when I have more news....
    MM.NET Member #3943
    I think you're right...disregard my advice above...
    Blog Entries
    2
    Dito w/ SergntMac.
    195,000 Miles & 275+ Runs Down the 1,320
    Vortech Super Charger V-2 T Trim, 19 PSI
    Aug 2005
    San Antonio, Tx
    Update: Currently at the dealership using their computer. Well, they tested it and as it turns out it is either a short in the wire harness or a bad soloniod (sp?) So basically something electrical in the trans wiring. So the car has to stay in the dealership overnight at least. We will see what happens tomorrow.
    Mike
    MM.NET Member #3943
  1. Battery Light came on...
    By djcwardog in forum Shop Talk
    Last Post: 05-14-2004, 02:20 PM
  2. Battery Light stays on!!!!!
    Last Post: 05-07-2004, 12:01 AM
