Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 32
Thread: Blinking o/d light and battery light
  1. #16
    Blog Entries
    2
    There is a casting boss near the firewall that can chafe the wiring harness.
    Try a search wiring harness chafe.
  2. #17
    Braselton, GA
    My o/d light started blinking at the track a couple of weeks ago. Tranny failed shortly after that.
    undefined2003 300A
    REINHART Vortech
  3. #18
    Dec 2003
    New York, USA
    Quote Originally Posted by SID210SA
    Update: Currently at the dealership using their computer. Well, they tested it and as it turns out it is either a short in the wire harness or a bad soloniod (sp?) So basically something electrical in the trans wiring. So the car has to stay in the dealership overnight at least. We will see what happens tomorrow.
    Mike
    Make sure all your keys work when you pick up the Marauder...
    If one of them doesn't, have them all recoded to the car again ASAP.
    Pete...
    DOB 10/31/2003
    DOP 1/2/2004
    DOB 12/11/2018
    DOP 6/19/2019
  4. #19
    Aug 2005
    San Antonio, Tx
    Quote Originally Posted by MENINBLK
    I am ahead of you on that one....I brought all my keys with me to work this morning.
    MM.NET Member #3943
    11/24/04 -'04 Silver Birch , Moon Roof, charcoal Interior,
    12/25/05 - Lower grill Mod - Thanks DEFYANT, 12/29/05 - OEM Spoiler - blankenship aero
    01/06/06 - Vynal Shades - Executive Signs Ltd., 01/06/06 - Silver Stars - MM.net (thanks everyone)
    01/11/06 - Remote start alarm ( North Park Linc. Merc. ), 02/16/06 - Pro Gurard - Reinhart Automotive
    02/24/06 - JLT CAI/RAI - JLT Performance(Jay Tucker), 06/14/06 - Godshead logo locking valve caps (Wes)
    02/14/07 - XCAL2 tuned by Lidio
    VEHICLES AND MILAGE :
    04 MARAUDER: 95,XXX (June 09) SOLD 1-28-14
    03 IMPALA: 126,XXX (June 09), Died Oct '11 143K
    01 SUBURBAN: 87,XXX (June 09) Traded in 9-22-12 123K
    07 SUBURBAN LT 4X4 84,XXX (Sept. '12)
    07 INFINITI G35 79,997 (Dec. '11) Her Ride!
  5. #20
    Aug 2005
    San Antonio, Tx
    Good News!!!! The Silver Ghost Marauder is ready for the road once again.....It was some bad soloniods in the Transmission....I will get back to yall on the technical jargon when I pick her up.
    MM.NET Member #3943
  6. #21
    St Clair Shores, Michigan
    Can you tell me how much the bad solenoids in the trans cost?
    My light blinked tonight and shifted funny. I pulled in a parking lot, shut it off and restarted it. Seemed to act okay. Will know more tomorrow.
    2012 Jeep Grand Cherokee Laredo-White
    2012 Jeep Grand Cherokee Laredo-Silver
    2011 Ford Fusion SE
    Retired 2003 Mercury Marauder/Trilogy 054
    Retired 2004. 13.00 on Nitrous safely tuned by Alt Auto.
  7. #22
    Aug 2005
    San Antonio, Tx
    I dont know but I will try to find out for you....mine was covered under warranty.
    MM.NET Member #3943
  8. #23
    Aug 2005
    San Antonio, Tx
    Thumbs down Update!!!
    Sorry it took so long, but I am in the middle of moving out of my apt into a house and kept forgetting to get my invoice.
    To answer question of price of solenoid: $47.53 Part # F8AZ-7G136-AA
    connector: $27.13 Pt. # F8AZ-7G276-BA
    And from the technician:
    CUST. STATES O.D LIGHT KEEPS FLASHING
    REPORT
    1
    ROAD TESTED AND VERIFIED CONCERN. PERFORMED TRANS DIAG
    EEC TEST CODES P0740-P0743. PINPOINT TEST. PRESSURE CONTROL
    TEST. FOUND INTERMITTENT TCC SOLENOID HIGH RESISTANCE
    REMOVED TRANS PAN AND REPLACED SHORTED SOLENOID AND
    CONNECTOR. CLEANED PAN. GASKET AND ADDED NEW FLUID. ROAD
    TESTED CLEARED CODES AND OK AFTER REPAIRS.
    MM.NET Member #3943
  9. #24
    Thanks a million for that information. I appreciate it.
    2011 Ford Fusion SE
  10. #25
    jerrykoziol Guest
    Extend Your Warrenty Now!!!
    I Had The Same Symptons With The Misshifting And O/d Light Blinking. It Happened Three Times On And Off Before I Actually Brought It In To The Dealer. The Are Currenly Putting In Remaned Trans.
    Yr And Mileage---03', 32,500 Miles
    Cost Without Warrenty 3,ooo$.
    Extend Your Warrenty If Possible As Soon As You Can To Avoind Cost.
  11. #26
    Aug 2005
    San Antonio, Tx
    I did not extend my warranty because I have mechanical breakdown insurance thur my "Little Green Lizard " friend.....They cover any thing mechanical or electrical that breaks...
    MM.NET Member #3943
  12. #27
    Denver, Colorado
    Question Keys and recoding???
    Quote Originally Posted by MENINBLK View Post
    What are we talking about here regarding the car and car key's being in "sync?" I am at a loss regarding the intended meaning of this comment. Thanks
  13. #28
    Aug 2005
    San Antonio, Tx
    The keys are coded to the car. Its call the PATS....or Passive anti theft system...each key, 2 regular keys and 1 valet, has a chip in them and need to be programmed to the system....so you just cant get a key cut and try to start the car cause it wont work. Hope this help a little cause thats all I think I know about it
    MM.NET Member #3943
  14. #29
    Dec 2004
    Canada
    Quote Originally Posted by SID210SA View Post
    REPORT
    1
    Thanks for the info.
    Just took mine to the dealership today. Blinking o/d light and engine light on. O/D not working (bad on freeway). They checked it out and said it could be one of two things and ordered parts. Said the pan would need to be dropped. Everything is covered under my basic powertrain warranty 5year/100K.
  15. #30
    Aug 2005
    San Antonio, Tx
    Any time....Hope this info helps get you back on the road soon!!
    MM.NET Member #3943
  1. Battery Light came on...
    By djcwardog in forum Shop Talk
    Last Post: 05-14-2004, 02:20 PM
  2. Battery Light stays on!!!!!
    Last Post: 05-07-2004, 12:01 AM
