towing, trans cooler, deep pan, and overdrive
Once I get the MM all setup to tow my small trailer (1 place snowmobile trailer, with snowmobile (~500#) and trailer, it should weigh under 1200#)
I am wondering whether or not I can/should use overdrive.
I will have an auxiliary trans cooler, deep trans pan, and temp gauge on the car before I tow. Is the overdrive band just to weak and going to be slipping the whole time while towing, or with these additions would I be fine in OD if i keep a close eye on the trans temps?
03 300A, Tint, FPN Tune
Lower Grill Mod
Flowmasters
Delete Tips
B&M deep pan
BC4E Dead Pedal
Larger than stock black Bullitts
