Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 72
Thread: Oil Pressure Gauge Conversion Part 1 of 2
  1. #16
    TripleTransAm Guest
    Interesting thought (at least, to me...):
    I wonder how it would look with the factory faceplate but no blue light bulb cover? ie. clear bulb only?
    Another interesting thought... I can always swap in the red bulb cover in December as part of the whole Xmas season look... LOL!
  2. #17
    WolfeBros Guest
    FWIW that blue bulb cover lights up pretty white looking to me.
    Yeah TTA.....Do a green in one gauge and red in the other.
    Santa might leave you a s/c kit to install.
  3. #18
    Mar 2003
    Las Vegas, NV (Henderson)
    Steve,
    Thanks, I appreciate it.
    You are exactly right about the needle, I should have clarified that, good thing you pointed it out for the others. And the same about "practicing" with the original gage to get the feel for taking the new one apart and getting it back together again. I kept the light just the way it came out.
    I have learned so much from this list I wanted to contribute something with the article.
    I'll be heading to Ennis in September, I'm looking forward to meeting people from the list and looking at all the cars..
    Jim
    1 of 111 Without Heated Seats
    6 CD Changer in Trunk
    Locking Lugs
    Trunk Organizer
    Marauder Side Emblems
    Rear Bumper Inserts
    Nephews: Blue w/Light Flint
    Born 02/05/03
    2011 of 7838
    Locking Lugs
    Trunk Organizer
    Factory Alarm
    Rear Bumper Inserts
    6705 of 7838 2003's
    Built Friday 02-07-2003
    Bought 09-10-2012
    #5 2003 DBP/Light Flint
    6741 of 7838 2003's
    Built Tuesday 02-11-2003
    Bought 05-06-14
  4. #19
    May 2003
    Waterloo, IA
    Looks like I'll be ordering the parts to do this conversion also. I had no idea the pressure gauge was fake!
    Thanks!!
  5. #20
    Oct 2002
    Milwaukee, Wisconsin
    Post
    When removing the bezels from the gages, I used Snap-op awl No. 3ASAAO. I carefully inserted it between the bezel and the cup and kept running it around the edge several times keeping continual outward pressure until the bezel came free of the cup. This kept the bezel from deforming using a screwdriver tip. When replacing the bezel I used the shaft of a Snap-on screwdriver No. SDD2. I ran the shaft of the screw driver around the bezel several times until it was snug you would never know I was in the gages.
    I did my sender connectors a little bit differntly. I bought two switches from Ford. I ground off the metal bases just like Vegasmarauder did. The next step I cut the spring in half, and got another brass nut like the one that came with the AM gage. I then threaded a 1 inch long screw into the nut just enough to hold the nut, I placed the modified spring into the base of the connector, centered the nut over the spring and wrapped a tie-wrap around the head of the screw and connector assembly. After that was secured I mixed up some epoxy and epoxied the nut into placemaking sure to adequately cover the nut and connector body so it wouldn't come undone and to keep the elements out. After about an hour, I removed the tie-wrap and the 1 inch screw and now I had a good sturdy and hopefully waterproof connector assembly to screw onto the Oil Sending Unit. It worked perfectly.
    I also made another connector assembly (in case the first one didn't work) which I ground off the flat part of the base of the connector leaving a smooth round barrel at the bottom of the connector. Next I took about a 6 inch piece of 18 ga. white colored wire and soldered it onto the metal tab inside the plastic barrel portion of the connector. After that was done I soldered a round connector(attaches to the sending unit) to the other end of the white wire. Again I mixed up some epoxy and filled the barrel portion of the plastic connector to seal it and to keep water and other elemnts out. I tested this assembly also, and it too worked perfectly. I wish I had a digital camera to show you how it looks. Hopefully I explained it thouroghly.
    Tim 49
    Tim 41
    Retired July 1, 2006
    "Somewhere Everyday We Fight For Life"
    2003 Mercury Marauder
    1. 300B (Pre-decontented)
    2. Born November 11, 2002
    3. Adpoted March 13, 2003
    4. 5945 of 7839
    1. 6 Disc CD Changer
    2. Factory Spoiler
    3. Sylvania Silverstars
    4. Escort Passport 8500 Radar Detector
    5. Pioneer TS- A6870R 3-Way Speakers
    6. Bob White Ruby Red Reflectives
    7. Mercury godshead steering wheel emblem
    .820 R/T, 15.356 1/4 Mi @ 92.42 MPH May 2003
    .792 R/T, 14.748 1/4 Mi @ 95.27 MPH Oct 2003
    1996 Ford Explorer XLT 5.0 V-8 AWD Mocha Frost/Saddle. Inservice May 15, 1996, retired October 2, 2004.
    2000 Ford Crown Victoria LX HPP 4.6 V-8 Harvest Gold/Medium Parchment Leather. Born July 25, 2000. Inservice August 29, 2000, retired March 13, 2003.
    2004 Mercury Mountaineer Premier 4.6 V-8 AWD Black/Midnight Grey Leather Sport. Born Jan 29, 2004. Inservice June 1, 2004, retired July 26, 2006.
    2006 Mercury Mountaineer Premier 4.6 V-8 AWD Vivid Red/Camel Leather. Born Feb 22, 2006. Inservice July 26, 2006.
  6. #21
    north nj (Planet Houston)
    a bump for this thread.
    i finished mine today.
    and the instructions where good.
    i'll add a few things i found out on my own.
    i used as many oem parts as possible.
    the oem face wont sit level in the am cup because the cup has little grooves in it. instead i drilled out the holes in the oem cup. the oem cup has 3 little markings on the bottom that is exatcly where the holes go.
    my biggest hang up , other then damaging the needle, was that the needle didnt seem to sit low enough on the pin. turns out the am plastic pieces are lower then the oem ones. i used the 2 little silver washer things from the am gauge and they worked great.
    the sender info is spot on.
    try not to slice to the trim ring with the screwdriver when you are putting back on..
    dont forget:
    the blue condom thing.
    the silver inch long spacers.
    where you put the nuts.
    that oil will come out from the place you put the sender. (about a pint or so)
    you don't replace that thing that looks like the oil sender, you just screw it on to what is there.
    big thanks to:
    marauder jack.
    vegasmarauder
    darebren
    and
    everyone else on this board. rock on!
  7. #22
    The Heartland of Indiana
    After install, what kind of pressures are you running,,, cold, warm, WOT, etc? Just curious because I just had mine installed and it seems a bit low.
  8. #23
    Zod:
    Excellent job, bro!
    mercman:
    With the "real" face, not the Ford one, I get about 100 lbs on a cold start, 25 lbs at warm idle in gear, and about 50 lbs warm cruising at 40-45 mph...YMMV
    Oct 2002
    Northern, Minnesota
    [QUOTE=the fat bastid]a bump for this thread.
    you dont replace that thing that looks like the oil sender, you add it!
    Do you thread the old sender into the new sender some how, so you can use the stock wire harness?
    '03 Mercury Marauder Born 8/02 Adopted 9/02
    Vortech Supercharger w/ WA intercooler
    Race prepped block
    Cobra block
    CP Pistons
    Manley Forged H-Beam rods
    Billet oil pump gears
    Stud Girdle (Its pretty)
    MMDS Drive Shaft, Metco Contrl Arms, Metco Watts Link, X-CAL2
    Meziere Ele. Water pump
    Addco Rear sway bar, Addco front sway bar
    PI 3000 stall torque converter
    4:10 Ford Racing gears, Ford Racing Rear end Girdle
    Rear engine cooling kit
    A-piller gauges- boost and fuel pressure
    KVR custome Brake KIt - RED
    Cobra exhaust manifold with X-pipe
    Level II tranmission kit
    180 STAT.
    Art Carr deep Tranmission kit,Tranmission cooler
    KVR stainless steel brake lines
    High preformance Twin cobra fuel pump, Reinhart HP fuel Filter
    Bob White decals on side mirror, side windows & bumper inserts,
    Splash Gaurds, KB Dead Pedal
    Eaton Diff. Mos. 31 spline axles
  10. #25
    Quote Originally Posted by Kelly
    You'll completely remove the old sender and replace it with the new one that comes with the guage. It's a piece of cake. A little thread sealer on the threads of the new sender and the brass adapter that it comes with and you're there.
    2007 Lincoln Town Car
    1993 Crown Victoria LX
  11. #26
    Oct 2002
    Northern, Minnesota
    Quote Originally Posted by Fourth Horseman
    I have the new AM gauges, just havn't been brave enough to tackle it yet. Thanks. Kelly
    Race prepped block
    Cobra block
    CP Pistons
    180 STAT.
  12. #27
    ^^^what Fourth said^^^
    Kelly: check your PMs...
    you don't replace that thing that looks like the oil sender, you add it!
    let me clarify that.
    if you check out your car you will notice something on the car by oil filter that looks like the sender that you get from am. you dont swap that one for the am one, instead you unscrew a seemingly harmless bolt next to it and put the sender inline there, which is shown in darebren's pic. So you don't replace that one you just add the am one to it.
    hopefully that makes sense now
    and i get about the same psi that rf does.
    25 warm idle
    50-75 cruising/gasing around town
    100+ when i floor it.
    remember, depending on where you zeroed your needle it will cause a difference
  14. #29
    Jul 2003
    Yonkers NY
    Hi,
    I was wondering about where would be the best place to buy the new Autometer oil pressure guage?
    Thanks
    Jay
    PS: This is the 1st mod I'm planning.
  15. #30
    Quote Originally Posted by jaywish
    jay, both Summit and Jeg's sell AutoMeter gauges... the oil pressure is P/N 4327 and goes for about $54 including the necessary sender. I've also seen them at various local speed shops...
    To paraphrase the Nike ads: "Just freakin' DO it..."
  1. Fake Oil Pressure Gauge Question.
    Last Post: 08-22-2010, 12:21 AM
  2. Adding an oil pressure idiot light, Part 1
    By drgnrdr33 in forum Shop Talk
    Last Post: 09-25-2008, 06:00 AM
  3. Replies: 19
    Last Post: 05-18-2005, 07:12 PM
  4. Mobil 1 - OK?
  5. oil pressure gauge
    Last Post: 10-28-2002, 12:02 PM
