Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 72
Thread: Oil Pressure Gauge Conversion Part 1 of 2
  1. #46
    Sep 2005
    Buffalo, NY
    Yeah, it's a little worrysome for me too. But I like the idea of getting a true reading. I ran it in my '78 T-Bird for 5 years without any worries. Who knows, I may not change a thing. There is a lot of beer to drink out there, and I plan on conquering that, one-at-a-time!
    Built: 3/16/2004
    Must - Go - Faster !
  2. #47
    Mar 2005
    Naugatuck, CT
    No, I have the AM replacements and they are full electric. I'm going to call Jeg's this morning to see what they have to say. It probably is the sensor, but I would vastly prefer to have a faulty gage, (it's much easier to swap that out and I don't have to get dirty ).
    P.S. If you need any help with all that beer, let me know; I'll be glad to lend you a hand!
    Constitution State Marauders
    2003 Mercury Marauder 300A
    K&N Aircharger CAI
    SCT Xcalibrator w/ Lidio tune courtesy of Innovative Interceptors
    Accufab twin 60mm throttle body
    FR 500 heads w/ Stage 2 cams
    Kooks full length headers
    Random Technology high flow cats
    custom welded 2.5 in. exhaust w/ Flowmaster Super 40's
    Drilled and slotted rotors from iRotors
    God's head locking valve caps
    god's head and S55 badges
    20% tint all around
    coming soon: S55 painted tail lights, and eventually, a Trilogy!
  3. #48
    Texas
    '15 F250 CC 4WD 6.7L PSD
    '11 CVLX
    '05 E55 AMG
    '91 350SD Turbodiesel
    '97 Land Cruiser/78 Land Cruiser
  4. #49
    So nate, you're saying that the needle on the gauge is stuck at the right-hand side all the time, or that when you turn the key on, it moves to the right and stays there? If it's the former, then the gauge unit is bad, but I would have thought you'd see that before installing it. If it's the latter scenario, then it does sound like a bad sender...try unhooking the white/pink wire either at the sender or at the back of the gauge...if the needle goes back down, then the sender is most likely bad. AutoMeter is usually very good with customer service...
    Sep 2005
    Buffalo, NY
    Quote Originally Posted by natedog1284
    I can always use assistance in drinking beer, as I make my own as well.... There are too many out there for one person to handle. But like they say, "divide and conquer".
    Built: 3/16/2004
  6. #51
    Mar 2005
    Naugatuck, CT
    Yes, the latter is the case. I have already ordered a new sending unit, which I hopefully will be installing tomorrow. BTW Wes, your write-up was awesome. I actually had my laptop out in the car so I could reference it easier! Everything went in fine; I did it while was changing the oil. And FYI, for anyone who hasn't done this, I did mine with the car on ramps, and it was very easy to get to. But when I stripped the end of the wire coming from the old sender, I just disconnected the other plug that was also in the same wire loom and brought the wire up through engine compartment so I didn't have to crimp the plug or attach it to the new sender while lying on my back. Of course if you have a lift, you won't have to worry about that. Also, given my position, I took off the plastic guard that's attached to the bottom of the radiator just to give my arms a little more room. Very easy swap overall; it took me about half an hour. It just goes to figure that the only reason I did the swap was to have a real oil pressure reading, and now I don't even have that. *sigh* Oh well, hopefully all will be well tomorrow. I'll keep you updated.
    K&N Aircharger CAI
    20% tint all around
  7. #52
    Jan 2006
    Montgomery County, MD.
    Thankx
    For all of the replies... I see the pic's i needed in the reviews section.
    BTW Wes great writeup! thankx again
    regards,
    ~mike
    2K4 DTR
    Trilogy #160
    some other lil' stuff.....
  8. #53
    Oct 2004
    Christian Co. MO
    every newer ford vehicle I have owned with a guage, was really a "light". on one of my powerstrokes I bypassed the voltage reducer on the guage pod, and replaced the sender with a unit for a guage, then the factory "guage" worked as it should.
    would this work on these guages?
  9. #54
    No. That work-around is only for the Ford gauges that are in the instrument panel. The AutoMeter gauges in the MM were designed to Ford's spec and will not work with the standard AutoMeter sender. Well, it'll work (sort of), but you have to replace both the sender and the gauge unit to get it to read correctly.
    Oct 2004
    Christian Co. MO
    ok, I have ultralites at work, so a swap is within easy reach. I looked quickly at the ones at work, I couldnt see a difference in the ford ones, except the name of the town across the bottom.
    why change the face?
  11. #56
    Jun 2002
    The photos from the original post seem to be gone. Anyone know where they might be?
    Member Number 32
  12. #57
    Quote Originally Posted by whd507 View Post
    The OEM Ford gauges are back-lit. The aftermarket AutoMeter ones have perimeter lighting and are not as easy to ready at night. The UltraLite II gauges are LED back-lit and more closely emulate the instrument panel.
    RC, Logan did an "upgrade" a few years ago and a lot of the older pix were lost. I believe they're in cyberspace now...
    Mar 2003
    Las Vegas, NV (Henderson)
    I found the photos I used when I wrote the original guage conversion. I will try and upload them again..
    1 of 111 Without Heated Seats
    6 CD Changer in Trunk
    Locking Lugs
    Trunk Organizer
    Marauder Side Emblems
    Rear Bumper Inserts
    Nephews: Blue w/Light Flint
    Born 02/05/03
    2011 of 7838
    Locking Lugs
    Trunk Organizer
    Factory Alarm
    Rear Bumper Inserts
    6705 of 7838 2003's
    Built Friday 02-07-2003
    Bought 09-10-2012
    #5 2003 DBP/Light Flint
    6741 of 7838 2003's
    Built Tuesday 02-11-2003
    Bought 05-06-14
  14. #59
    Jun 2002
    Quote Originally Posted by vegasmarauder View Post
    Thank You!
    Member Number 32
  15. #60
    Jun 2006
    Central New Jersey
    Quote Originally Posted by RCSignals View Post
    Thank You!
    Ditto!!!
    Build Date 3/19/04
    Adopted on 10/19/07
    Seq#2102 of 3214
    #681 of 997 SBs
    #154 of 336 SBs with the moonroof
    Thanks Brian
    Member of The 100K Club 11/20/11
    Options-
    moonroof-heated seats-6-disc changer-trunk organizer-rear spoiler-mercury all weather mats
    Mods-Extras-Bling-
    Action Automotive-SS Inserts
    Auto Meter 4327 Oil Pressure Gauge
    Badgeless Grille(Thanks 03 Merc)
    Big Mike's Performance-"Sto n Sho" License Plate Holder
    Dead Pedal(Thanks lji372)
    Curless's Pedal Gear Repair
    Cruzer's-Arm Rest
    EATC Ungrade(Thanks JACook)
    Escape/Audiophile Radio Upgrade(Thanks shodude)
    Ford Racing M-7195-AOD Aluminum Trans Pan
    Innovative Interceptors-God's Head Valve Stem Covers
    J-Mod Valve Body
    K&N Performance Intake Kit{CAI}
    LCM Upgrade(Thanks Fastblackmerc)
    Marty-O Fender Badges, Tune & 4:10s
    Panther Lights HID Headlights
    Pro-gard Skid Plate
    Rear Cooling Head Mod
    Visteon Sirius Satellite Radio Setup(Thanks RoyLita)
    Weather Tech-Side Window Deflectors
  1. Fake Oil Pressure Gauge Question.
    Last Post: 08-22-2010, 12:21 AM
  2. Adding an oil pressure idiot light, Part 1
    By drgnrdr33 in forum Shop Talk
    Last Post: 09-25-2008, 06:00 AM
  3. Replies: 19
    Last Post: 05-18-2005, 07:12 PM
  4. Mobil 1 - OK?
  5. oil pressure gauge
    Last Post: 10-28-2002, 12:02 PM
