Originally Posted by
ckadiddle
Hyundais have a very unique shrill squeal when stuck under a Marauder. Kias tend to get wrapped up in the pulleys and belts on the front of the engine, so they usually go clunkety
whineclunkety
whineclunk.
I agree....Hondas never cause these types of noise, as they are always BEHIND a Marauder!!!
