Originally posted by sandman
Check to see if the bottom of your doors still have the drain plugs in them, if so pry them out. This may solve your problems. This was discussed before you may want to search it. Only one of my doors had the plugs in it, the other three did not. Hope this helps. Water in doors=bad!
I finally checked my doors. The driver's side does not have the plugs but the passenger's side does. I removed them and noticed that they are designed so when the plugs are in the drain holes there is a gap at the top and bottom to let air/water pass freely. The day before we had driven through torrential rains in AL and MS for a couple of hours. There was no accumulation of water on either side. I'm leaving them in the passenger's side. Maybe it will keep geckos and other creatures out of those doors.
ostentatious: "intended to attract notice and impress others."
SergntMac's first MM adopted 7/5/03. (I bought it for my wife. Honest.)
'66 Mustang Conv resto-mod always in process.
'96 Mustang GT bone stock.
