Results 1 to 15 of 15
Thread: 8-Bolt Flywheel for auto tranny help needed....
    Jun 2005
    North East PA
    I pulled my motor and had it redone to a 5.0L
    This was accomplished by use of a fully balanced...yada yada yada...
    but an 8-bolt Crank... Cobra motor crank...
    I tryed to have F/L/M dealer order me a an 8-bolt flywheel to maych my new crank and was called back saying it is an impossiblity...
    that there has never been an 8-boly auto therefore the part doesn't exist...
    Would someone either point me into the correct aftermarket direction or provide me with the info to take back to the dealer and make them eat their words.... lol
    I know other have used the 8-bolt crank and out auto tranny so it does work... members such as "fordnut" have done this...
    Jun 2005
    East Lansing, MI
    Quote Originally Posted by Loco1234 View Post
    wow... why didn't you just get the right bolt crack? that aside didn't the cobra come in an auto verson too? I really have no clue, just throwin ideas out there. Still I'm curious as to why you didn't just go with the one that would fit for sure.
    11.90 @ 117.5mph on 93 octane
    Igziabeher
    Jun 2005
    North East PA
    Quote Originally Posted by RR|Suki View Post
    u have the same basic stroker crank i have only i didn't go with stroker rods.... so im only at 5.)L
    The setup is from VT like yours but I habd a local guy do assembly because i did alot of other custm parts... similar to "fordnut" such as the ceramic & telfon coated pistons...
    Im sure your stroker crank is an 8-bolt what flywheel did u go with...?
    The 99-00 GT motor used an 8 bolt crank. You can use one from that application.
    But since your motor is a performance part, I'd suggest calling Performance Automatic and buying one of their SFI flexplates.
    Either way, there's your 2 options.
    Sal Mennella
    Power Surge Performance
    Ford Tuning and Performance Specialists
    Project MadMax2006 - 2000 Police Interceptor 5.4 Lightning Whipple Supercharger powered
    590 rwhp 630 rwtq 11.39 @ 121mph 1.61 60ft 155k Miles
    Jun 2005
    East Lansing, MI
    I'm actually at 324 because I'm bored as well, on the flexplate question, it should be in the ford racing catalog... or see above ^
    Igziabeher
    Brampton, Ontario, CANADA !!
    Quote Originally Posted by Power Surge View Post
    XR3Z 6375 EA is the OEM Ford part number for that flexplate, if that's the way you choose to go.
    cheers
    Ed N.
    Jun 2005
    East Lansing, MI
    Igziabeher
    May 2005
    Amissville VA
    I thought I heard once that the F150 truck flexplate would work too (atleast with a Cobra motor swap to the stock trans) but I'm not sure what years...
    But sounds like you already got some optoins.
    Trilogy #112 (self installed)
    12.99@106.2mph (for now)
    Jun 2005
    North East PA
    I ordered the Flywheel/flexplate:
    http://www.performanceautomatic.com/flexplates.htm
    PART# PA26478-8
    it's supposed to bolt right up to my new 8-bolt crank...
    It is aslo SFI certified...
    Jun 2005
    East Lansing, MI
    PART# PA26478-8
    you should be good as gold, never go to the dealer for squat
    Igziabeher
    PART# PA26478-8
    That's what I used.
    Art Carr also offers one, but it's not SFI certified.
    Another company also sells them, but they are ALWAYS on backorder.
    I love it when a dealer says "there's no such thing", but 5 minutes later someone here lists the part number and the vehicle it was used on...
    The members here are simply awesome!
    Jun 2005
    North East PA
    LOL YA the member on here are great...
    and thanks "fordnut" I feel alot better knowing thats the one u went with...
    especially since your up and runing I know there won't be some hidden issuse....
    thnx
    Yeah I used the PA one too on my car. Yes, the 5.4 truck (non-Lightning)flexplate is the same part with 8 holes. Come to think of it, I have one laying around the shop somewhere.
    Sal Mennella
    Jun 2005
    North East PA
    ...SO THE ONE SITTING 10FT AWAY FROM ME.... THAT WAS ON MY 2000 NAVIGATOR WOULD WORK...?
    ( I PUT A NEW MOTOR IN IT...) A 2003 MOTOR.. MORE POWER/BETTER CAMS....
    HMM..
    IM BUYING NEW.. lol
  1. My tranny cooler install
    By O's Fan Rich in forum Community Discussion
    Last Post: 07-26-2006, 03:18 PM
  2. Bolt thread size for tranny to engine?
    By TooManyFords in forum Shop Talk
    Last Post: 02-01-2006, 03:59 PM
  3. Steeda Chrome Bolt Caps
    Last Post: 08-22-2004, 07:31 PM
