Results 1 to 4 of 4
Thread: P71 axle shaft bearing replacement
    Sep 2004
    Roanoke, VA
    Recently I had been hearing a faint noise when braking unlike any other braking issue I've ever diagnosed, and I wondered if it might be a rear wheel/axle bearing. Sure enough, after driving a few thousand miles I just noticed a little drip on the inside on the LH tire. I have torn many Ford 9" rears apart but I don't have any experience with this 8.8. So my questions are:
    1. Are there any tricky issues with the differential lock pin and C-clips?
    2. In case the shaft is now galded, is there a Ford axle kit for this application (95 CV P71) as I hear about for the 300A Marauders?
    04 MM Silver Birch/Light Flint, HS, TO, 6CD, #597 of 3214 (sold 5/2014)
    06 MGM LS Ultimate w/HPP, Black/Dark Charcoal
    04 MGM LS Ultimate
    69 Marquis convertible, 429
    95 F250HD 7.3 4x4
    48 Ford F4
    Purgatory, FL
    Unfortunately, there is no axle kit for the 95 P71. After the cover comes off, you need to remove the pinion shaft and bolt. Use the box wrench for access the bolt. If your CVPI has ABS, then the sensors need to be removed to be able to push the shaft in to access the c-clips. If you have a small screwdriver, you could push the clips out. The high tensioned "S" spring (if equipped) does not need to be removed.
    (#6178 in black per FPIC)
    Rest In Peace:
    Paula Babineau 1/9/67-8/2/11
    Rex Weinbender
    Peter
    Sep 2004
    Roanoke, VA
    Thanks a bunch Roy. Currently the LH caliper and rotor are off, now for the cover. I sure hope the shaft is still OK. This unit is a trac-lok without ABS. I'll keep you posted.
    04 MGM LS Ultimate
    95 F250HD 7.3 4x4
    48 Ford F4
    Oct 2004
    Indianapolis
    There is a guy on ebay that has a very good DVD on how to overhaul the 8.8. His name is Kenneth Collins and the company name is BadShoe Productions. If you can't find him on Ebay I might be able to look up his email address.
    Tom
    2003 Marauder 300B, Blue
    Trilogy 0003
    Lidio Tune
    MMX / 4.10s by Kenny Brown
    Trilogy 0013
    Dual position chip
    California CARB test car
    2003 F-250, Gray
    2003 Excursion, White
    1996 Corvette RPO Z-16, Blue/White, Red Leather
    1996 Corvette, Red, Red Leather
  1. Highest mileage (warranty) axle replacement?
    By MMM2003 in forum Shop Talk
    Last Post: 08-07-2006, 10:26 AM
  2. Performance Driveshaft
    By Silver03MM in forum Shop Talk
    Last Post: 07-28-2006, 08:02 PM
  3. bearing replacement
    By duhtroll in forum Shop Talk
    Last Post: 12-21-2004, 12:56 PM
  4. Axle Bearing Noise
    By AJAX in forum Shop Talk
    Last Post: 11-15-2004, 05:59 PM
  5. Aluminum driveshaft
    By RCSignals in forum Community Discussion
    Last Post: 12-02-2002, 07:24 PM
