Hey Guys,
If you ever hear of someone else importing a MM into Canada from the States, here's an idea for the legal requirement of full-time daytime running lights.
Canadian Tire (the contracted federal inspection shop) charges $191 plus tax to install the light kit. I simply used 3 blade connectors and 2 pieces of #14 wire. Cost me about 17 cents!
A simple way to pass the test is to remove the right and left headlight fuses, and make a jumper wire from them to a single blade connector, and put it in the power window relay slot. The windows get power with ignition on, so the lights come on immediatley. Each headlight is a 10 amp fuse, and the power window circut is a 25 amp relay. As soon as you get home, YOU HAVE THE OPTION to remove the wire and replace the relay. Not that I'm advocating that or anything....
