Results 1 to 13 of 13
Thread: Effective gear ratio with tire size correction
    So I have been really on the fence for a while about getting 4.10s because I do a lot of highway driving but I think I have finally been pushed over into buying some. With some calculations my current ratio with my 255/55-18 tire with 3.55 gears is 3.50 and if I go with 4.10s my new effective ratio will be 4.04 with the same size tire.
    Now if I run a 255/50-16 drag radial with 4.10s my effective ratio will be 4.57.
    I think these numbers are off slightly, could anyone check what my effective rear gear ratio will be with 255/50-16 (26" dia.) and 255/55-18 (29" dia.) while using 4.10 gears?
    I do remember a few people telling me with using a 255/50-16 drag radial and 3.55 gears my effective ratio would be 3.89/3.90, when I used the calculation method I came up with 3.95.
    300B
    Exhaust by Greg
    2015 Ford Focus SE Sport FWD
    2010 Ford Fusion Sport FWD
    maybe this isn't what you want after all.
    Oct 2003
    Beaufort, SC
    Keep your 3.55 gears and use small tires at the track......BEST OF BOTH WORLDS!!!
    Apr 2005
    Queens NY
    I guess a tweak in my tune for my 255/55's in the rear has to be done?
    2003
    MERCURY MARAUDER 300A
    Build Date
    5/31/02
    Sequence#
    #363 of 7839 Black Marauders
    Dyno tested power
    Best 1/4 mile time to date
    12.456@109mph
    Visit my Garage
    Blackened300a's Garage
    Jun 2007
    Boston
    Quote Originally Posted by Blackened300a View Post
    Ah,,, this may be why you had trouble getting to 135 in 7500 ft, and I got to 136 and even had to let go of the throttle before I topped out...
    Yes, larger tires will lie, and tell you that you are going slower than you really are.
    I will post a formula to help everyone figure this out:
    I believe that our computers calculate speed based on RPM of the transmission output shaft, using 245/55/18s as a constant.
    245/55/18 = 7.490 ft roll out = 704.9 rev/mile
    255/55/18 = 7.604 ft roll out = 694.4 rev/mile
    ((704.9-694.4)/704.9)*100 = 1.49% less speed indicated on speedometer.
    So, if your computer said you hit 135, we can use a simple proportion to calculate your actual speed:
    135/694.4 = x/704.9
    x=137
    So, you went 137 the other day. 2 MPH off in 137, isn't that much, you may not find it worth the cost of calibration. It means you are 1 MPH off at 67.5.
    Hope this helps.
    By the way, what RPM were you going at 135? When I did my run, I didn't hold it out of OD, but let it go in natually, which it did do at around, I think 120...
    fastcar
    Jun 2007
    Boston
    Sorry, Raven,
    To help you out, you figure roll out as follows:
    divide tire size by 25.4 (ie 255/25.4=10.04)
    multiply series by 2 and divide by 100 (ie 55*2=110/100 = 1.1)
    multiply this by 1st number (1.1*10.04=11.04)
    add this to rim width (11.04+18=29.04)
    This give tire height in inches. Divide by 12 for feet.
    =2.42
    multiply by Pi (3.14) for diameter = 7.60
    NOW YOU HAVE ROLLOUT.
    For rev per mile divide 5280 by 7.60 = 694.7
    Compare your tires using this formula, and you can determine how much to adjust.
    fastcar
    Apr 2005
    Queens NY
    Thanks for the chart, 1 mph really isnt worth going crazy to have a tune sent to me.
    I ran flat out last summer and I remember hitting close to 6K rpms before I shifted into O/D, then it dropped to about 5K I think and it was the slow climb from there.
    2003
    Build Date
    5/31/02
    Sequence#
    Dyno tested power
    12.456@109mph
    Visit my Garage
    Jun 2004
    FWIW, speedos are not always accurate. Returning from MVV I went through three construction zones on I81 that had radar carts. Each time my speedo matched the radar read out. I have the 255/55/18's.
    Jun 2007
    Boston
    A little off subject,
    But what is the part number for the BFG 255 55 R18 everyone is using? I can't find it at their website...
    Also, what tire is everyone running up front, when using this in the rear. Ideally, a 45-50 series 245-255 would look perfect, but no matching tire in BFG is available... I do NOT want to run 55s up front.
    thanks,
    fastcar
    I am running the BFgoodrich KDW"2" 255/55-19 tire. They stop making them Dec 2005 from what I have heard. I run the oem 235/50 up front. I did want to go to a 245/45 but again they stopped making the KDW"2" flame pattern summer only tire .
    Yeah I'm not worried about revs per mile or anything cause I have a Xcal2 to adjust them. What I am trying to figure out is what my effective rear gear ratio will be with using my current tire and drag radial with 4.10 gears.
    Either way I am going to get 4.10s now.
    300B
    Exhaust by Greg
    Apr 2005
    Queens NY
    They stopped making the KDW2??
    I thought you had 4.10s? Thats the final piece of the puzzle to help you get firmly into the 13's
    2003
    Build Date
    5/31/02
    Sequence#
    Dyno tested power
    12.456@109mph
    Visit my Garage
    Yeah I posted a thread up about them a while ago and another one surfaced last month about them.
    I know I can get into 13's without them but I had the heat and no re-tune for the 3500 stall working against me (mid-range bog down) at MMV. After I got the re-tune the car acted just like when I installed the Xcal2 tune for the very first time, night and day performance difference. I was thinking that I may just wait until spring to do them because I'd like to do 31-spline axles and a Eaton LSD while I'm upgrading things back there.
    300B
    Exhaust by Greg
    Jun 2007
    Boston
    Are you having trouble with the Ford trac-lok unit? Mine works awesome. If your's needs rebuilding the clutches and labor are cheap (esp if your gears are coming out)...
    fastcar
  1. HELP- correct winter tire size??
    By Jay Stark in forum Shop Talk
    Last Post: 12-22-2003, 05:26 PM
  2. one size tire for Marauder?
    By FLMARAUDER in forum Tires & Wheels
    Last Post: 09-27-2003, 02:53 PM
  3. Tire size and ABS ?
    By MM03 in forum Tires & Wheels
    Last Post: 03-28-2003, 10:51 PM
  4. Tire size vs Gear ratio
    By prchrman in forum Tires & Wheels
    Last Post: 02-10-2003, 03:45 PM
  5. non-stock tire size (eliminate stagger)
    By russ in VA in forum Community Discussion
    Last Post: 11-15-2002, 11:17 AM
