Results 1 to 7 of 7
Thread: Tach Problem
    S. Hillsboro Co.
    Tach Problem
    Ok, before I get the "use the search function " please know that I have tried and I am not real good with computer stuff. Couldn't find it. So if anyone can help me with this it will be greatly appreciated. The Tach problem occurs randomley. At Idle it will sometimes drop to zero and I can tap the dash and it will resume operation. sometimes while driving it will do the same. Not a major crisis but annoying. Hell I don't know how to list my mods, or change my avatar"whatever that is?"
    Oct 2005
    Southwest Florida, Lee County
    Your avatar is the waving flag next to your username. Your tach issue is apparently a cluster problem. Go to "quick links" and hit "edit my signature". List your mods there.
    2004 Mercury Marauder
    2,187 of 3,214
    997 in Silver Birch
    448 with light flint interior
    304 with heated seats
    336 with sunroof
    S. Hillsboro Co.
    Thanks. Will continue my search.
    Sounds like it could be either the connection to the cluster or the cluster itself. Pull the cluster, unplug and re-connect the connector. If that fixes it, great. If not, time to start looking for a replacement cluster.
    S. Hillsboro Co.
    Thanks for your input Brian, I was wondering if it might be at the other end of the set up, the sending unit as it were also??? I am probably using the wrong terms here but maybe someone could elaborate. Thanks again for any and all info on this matter.Vince.Brian I will check the connection at the cluster and let you know if it worked.
    I believe the "sender" is the PCM.
    S. Hillsboro Co.
    thanks again
  1. Need Help with Autolamp/Lighting Control Module problem
    Last Post: 11-22-2010, 05:57 PM
  2. Marauder cold start problem SOLVED FYI
    By Aeroman in forum Shop Talk
    Last Post: 10-02-2007, 06:03 AM
  3. Overdrive Problem
    By HBTMD in forum Transmissions
    Last Post: 07-28-2007, 11:42 AM
  4. Radio Removal / Antenna Question and Problem
    By Svashtar in forum Community Discussion
    Last Post: 10-24-2005, 12:19 AM
  5. Idle Problem
    By tekguy in forum Shop Talk
    Last Post: 01-29-2005, 09:41 AM
