Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 53
Thread: wider rear tires size?
  1. #16
    Aug 2006
    MA
    Wider? No, taller? Depends if you have T/C, or the ABS could throw a fit.
    445rwhp/408rwtq - 12.6/110mph
    DR Vortech NOIC #5
    Sold
  2. #17
    Feb 2008
    Boston
    Does anyone know how wide I can go in the rear go on a stock width rim
  3. #18
    Jan 2008
    +34 Dg 32' 39" X-82 Dg 40' 24"
    Community Discussion, Cut My Rear End, a post by Rufustlestrat says he has 255X45X18's on front, and 295X45X18's on stock wheels on the rear, has a picture, looks good!!!! some one else said 305's, I thought it was DR?
  4. #19
    Purgatory, FL
    Arrow +1
    Quote Originally Posted by ckadiddle View Post
    Dennis Reinhart is running Hankook 295 width on stock rims (rear).
    I have them too courtesy of Red.
    (#6178 in black per FPIC)
    Rest In Peace:
    Paula Babineau 1/9/67-8/2/11
    Rex Weinbender
    Peter
  5. #20
    Charlotte, N.C.
    Quote Originally Posted by sd8683 View Post
    You can go SAFELY to 255 on OEM Wheels--beyond that I do not recommend it--regardless of who is or who tells you different....even though several owners are doing it as mentioned -----but the word IMO is SAFETY---as for me--got 255 up front --295 on widened wheels on the rear......works for me....good luck
    12.45 at 109.6 MPH
    1.92 Sec .- 60 '
    Alt .SSHS 9 --11/7/09
    '06 CV P71 Street Pkg
    Interior Marauder Floor Shift
    All New Parts
    In Memoriam....11-14-13
  6. #21
    Nov 2005
    USA
    Quote Originally Posted by trash View Post
    I have never heard of anyone putting 305s on our 8" rims.
  7. #22
    Nov 2005
    USA
    Quote Originally Posted by RoyLPita View Post
    How are they working out for you? Did the higher pressures help with the squish?
  8. #23
    Manalapan, New Jersey
    What about with wider rims? I was told that we have to look out for our suspension when moving to larger tires. A member over at the crownvic.net forums with a 2000 crown victoria is running 325/50/R15's out back and they don't hit anything because it has a different suspension than us. Would we be able to run 305 tires on 16 inch rims?
  9. #24
    Boston
    What do you guys mean by saying 295 on a widened rim? How do I make my rim more wide?
    -Eric
    2004 Marauder - Best Dyno: 277whp 295wtq
    Mods: Kooks, DEZ tune
  10. #25
    Nov 2005
    USA
    Quote Originally Posted by Eric-Blk2004 View Post
    Our stock rims can be widened from 8" to 9.5". There were a couple vendors who would facilitate this service (they had shops do this for them). It can cost as much as $300 per wheel, not including the cost of the wheel. Do a search to find out more information, and better yet, collect the information you find and post it on the Marauder wiki (MyMarauder.com) under the wheels section. Thanks!
  11. #26
    Aug 2007
    Minnesota
    295's on 8" rims is dangerouse as hell, your streatching the sidewall way too much, and if you hit a good sized pot hole I'd bet the bead on the tire would let loose! A few years ago I tried puting 245/50/15 on 8" steels, couldn't even get them to bead up....my $0.02
  12. #27
    May 2005
    Amissville VA
    I have heard of people doing this and I would NOT recommend it. 295 is way to wide for stock rims. I'm sure some will disagree and say they do it with no issues but to each his own regardless of that based on design specs and safety specs 295 is too wide for a non-widened OEM Marauder rim.
    265 if the upper limit on stock rims, 255 really is as wide as you should go to be within recommended specs.
    Trilogy #112 (self installed)
    12.99@106.2mph (for now)
  13. #28
    May 2005
    Amissville VA
    When your in the 255 - 265 range all you can find are high performance / light truck tires. I use these:
    Hankook RH06 in 255/55/18
    At $125.00 a pop and they wear like iron.
    Got them at www.eastcoasttires.com
    Those look pretty cool...is there a front size available? I like the same tread on all four corners personally.
  14. #29
    Jan 2006
    Central Ohio
    295/45-18's here, on STOCK WIDTH WHEELS!!!
    KillJoy
  15. #30
    May 2005
    Amissville VA
    Quote Originally Posted by KillJoy View Post
    294/45-18's here, on STOCK WIDTH WHEELS!!!
    KillJoy
    Where'd you find 294 width wheels?
  1. KDW-2 Rear Tires
    By Smokie in forum Tires & Wheels
    Last Post: 11-26-2007, 08:53 AM
  2. wider rear wheels
    By evillost@adelph in forum Tires & Wheels
    Last Post: 12-05-2006, 04:20 AM
  3. My new tires...
    By SergntMac in forum Tires & Wheels
    Last Post: 07-28-2005, 06:09 PM
  4. All 4 tires same size??
    By jcb100 in forum Tires & Wheels
    Last Post: 03-21-2004, 06:05 AM
