Results 1 to 15 of 28
Thread: Cylinder Head Temp Gauge
    I just got this feature working on my ScanGauge yesterday.
    My question is, does it exist, where is it and can you prove its really on the car?
    Seems to me it must be incorporated into one of the sensors in the coolant crossover tube, which is pointless since it wll always read the same as the water temp.
    FYI, the CHT and ECT are always withn 2-3 degrees of each other.
    I looked for a threaded CHT port when I was installing all my gauges and never found it.
    I ended up adding a sensor in an unused threaded port that is in the 'lifter valley' under the intake manifold.
    It is essentially reading the block temperature.
    Now I have both the Autometer temperature gauge and the OEM gauge working.
    i hate those things! well workin on plane motors with them. one for each cylinder most of the time being as each cylinder is its own unit. stupid little conector thing. any way ill stop rambling now
    May 2006
    Cherry Hill, NJ
    Zack....I can't tell you exactly where they're located in the heads, but the sensors are there, screwed into the heads. They are the only initial link that keeps you from melting down the motor in case of coolant loss by shutting down cylinders. During a a catastophic loss of coolant, or a stuck thermostat, the ECT sensor is not quick enough to determine that there is a problem. During normal operation, the 2-3 degree delta is normal, as one would expect, since coolant is properly flowing.
    BTW, if you really want to see something neat with the ScanGage2 tool, set it up for HP. Don't forget, it displays gross hp, not net. So far, the best I've been able to observe is 345 hp. Unfortunately, it's tough to observe the gauge while doing a WOT start, as well as the fact that the meter only updates, at best, once a second, so you will miss the peaks.
    - Randy
    2004 MM (Wine Red [it looks like wine to me!])
    XCal2/Blue Oval Chips Programming
    1996 Impala SS (12.45 NA)
    Oct 2003
    Beaufort, SC
    My CHT reads a couple of degrees higher than water and I cannot make it spike up with hard running!!
    Beats me where the sensor is but I guess if you ran HOT the CHT would go wild??
    Marauderjack
    Quote Originally Posted by racorcey View Post
    I would love to believe that, cause Ive had MANY Mod heads stripped down to bare aluminum and never saw them.
    Again, can someone PROVE they exist?
    Aug 2007
    Dale City, VA
    When you say mod heads i am going to guess youre only talking about marauder heads because my 97 cobra had one in each head right in the front
    First
    On
    Race
    Day
    Never trade the thrills of living for the security of existance....
    Never hold your farts in, they travel up your spine into your brain, that's where ****ty ideas come from
    2003 Mercury Marauder 300A BLACK #2,740 of 7,839-Daily Driver
    JLT, 4.10's, Lidio Tune, PHP Intake Spacer, NGK TR6 Plugs, FlowMaster 40's with second cats deleted, J-MOD, ScanGuageII
    1/8 Mile-9.2
    1997 Cobra-Sold...The car I will always miss
    1993 Mustang LX 5.0-SOLD
    1991 Mustang GT- Stock, kinda... SOLD
    1992 Mustang GT-64,000 Original Miles R.I.P.
    Quote Originally Posted by VAmarauder03 View Post
    Correct
    67890
    May 2006
    Cherry Hill, NJ
    I will consult with my resident expert from the CVN forum, JohnG. We just talked about them last night, ironically enough, but I wasn't awake enough to remember to ask where they were located.
    While I wait, if someone has a service manual handy, they could find them just as quickly. I'm at work at the moment so I can't get to my books.
    - Randy
    - Randy
    There are no temp sensors, dont bother!
    I have totally disassembled my motor a couple of times, don't recall any CHT sensors. Only one sensor I haven't bothered to identify, one on each side, attaches to the valve cover near the top rear bolt on the driver's side and closer to the center on the passenger's side. What are those sensors?
    I dont think they are sensors.
    They remind me of condensors for the ignition coils.
    Aug 2007
    Dale City, VA
    I just got 374hp out of my scan gauge tonight, im pleased for not being the peak
    First
    On
    Race
    Day
    1/8 Mile-9.2
    May 2006
    Cherry Hill, NJ
    Allright! I haven't done anything to my car except for a tune, t'stat, and plugs. I guess in theory, I should be seeing more, but yours sounds like a good start.
    BTW, what have you done to your car?
    - Randy
    - Randy
    May 2006
    Cherry Hill, NJ
    I don't quit so easily. I checked with my source from CVN as well as a Ford mechanic friend. Both of them say there is one sensor (and one sensor only) for CHT. It is located just under the intake manifold, near the front, by cylinder #5 (driver side). Not viewable on 4V motor when looking at the engine compartment, although it can be seen on the 2V motor.
    - Randy
    - Randy
  1. Oil Pressure Gauge Conversion Part 1 of 2
    Last Post: 09-09-2019, 01:38 PM
  2. Why the cooling mod is important
  3. stock water temp gauge
    Last Post: 08-30-2005, 07:30 AM
  4. OEM temp gauge
    Last Post: 07-11-2005, 03:05 PM
  5. My newest mod - Tranny temp gauge
    By Logan in forum Community Discussion
    Last Post: 06-20-2004, 11:11 PM
