heated seat green light keeps blinking on and off.....guage light isnt workin no more....is it expensive to fix..anyone know?
Which gauge? ...one in the dash or one in the pod? If it's one in the pod, then that's an easy fix. Grab the "wings" on either side of the pod and pull down, then rotate forward. The bulbs are easy to replace.
As for the heated seat switch blinking, I'm trying to get an answer for that one myself.
Gauge bulbs are easy to replace... getting to them is another matter most of the times. I think resoldering the resistors ala the seat switch fix will fix the blinking heated seat switch problem. If not you need to replace the switch(s).
Luckily, mine did this while still under warranty and was replaced.
It is possible to repair the switch, but it's a real bite. Basically, the solder joints for the voltage dropping surface-mount resistors don't hold up well with temperature and vibration, and then they either become intermittent or open, resulting in no LED light output. Sometimes the LED's themselves also suffer from the same problem. Taking the switch apart to fix this problem is also difficult.
Assuming you're not under warranty, might be easier to buy the switch and do your own door panel removal. Once the door panel's off, it's pretty easy to replace the switch.
- Randy
2004 MM (Wine Red [it looks like wine to me!])
XCal2/Blue Oval Chips Programming
1996 Impala SS (12.45 NA)
My drivers side is going on and off again. It was fixed under warrant 2 years ago.
03 Marauder 300A, 6 CD Changer, tint, SS Inserts, McGard wheel locks, Full Stainless Works 3 inch exaust and long tube headers, DynoTech MMX driveshaft, Spoiler, Full godshead treatment, Mack & Marty fender badges, Mac & Zack Control arms, KB dead pedal, Adco rear sway bar, 4.10's, FIT/ProCharger Racing Team Member #019(Mine)
04 DTR Cd Changer, moon roof, heated seats, trunk organizor, McGard wheel locks,
SS Inserts, Spoiler, tint, godshead stearing wheel badge, Badgless Grill & trunk, Densos & 180 t-stat, Megs Resonator Delete Tips, Flowmaster 40's, Mac & Zack Control arms, KB dead pedal, Adco rear sway bar, Superchips 9100 SCT tuner, JTL CAI, and 4.10's. (hers)
67 Galaxie 500
96 F250 EXT Cab 4X4 Pwerstroke
2013 Lowe SS210
98 Mustang convertible
2005 Sportcoach Cross Country 376DS
The heated seat lights should be the same or similar to the window switch light fix I posted ----> http://www.mercurymarauder.net/forum...+switch+lights
I wish I had the heated seats so I could wright up an exact fix for those.
My MM is in the dealership looking to get this fixed before the 3 year warranty is up. Tech says he may have to remove front seats to search for problem????
Anyone have a definite fix for this problem? Maybe I could start the conversation off with "I read on the internet" and watch the tech's face turn red .
Thanks.
If you need help with the gauge let me know
2003 300A Black MM
FRPP ALUMINATOR MOTOR 10:1
STAINLESS WORKS LT HEADERS
ADDCO FRONT & REAR SWAY BAR
MONROE HD QUICK STRUTS FRONT
QA1 ADJUSTABLE REAR SHOCKS
