Originally Posted by
John F. Russo
Again I come to those who have provided the most consistent help over the years. And it costs nothing! That's what friends are for they say. I agree.
Problem
My Kenny Brown car (profile below) has occasionally skipped when in a WOT situation. I have decided to study what is causing it.
Conditions when engine "skipped"
Recently it has happened after about 10 seconds in WOT at about 70 mph. All of sudden there is a hesitation for about one second then it takes off smoothly. I had more than 1/2 tank of gas and the car had been running at this speed for about 20 minutes.
Other Data
Each time it has happened it skips exactly the same way. I have never had any service performed on the supercharger. I have never replaced the plugs because my dealer says they are good for 100,000 miles.
What other data do I need to collect to determine what is causing this problem?
2003 Dark Blue Pearl 300B (Canadian) w/Light Flint (reversed traction control, mini spare, trunked 6 disc CD changer, clock-in-the-radio, heated front seats/mirrors, hood light), Born 12/10/02; converted new then used 2/28/03; 70,000 miles
ENGINE: Kenny Brown: 6th “Signature Series” conversion, Vortech supercharger (5 to 7 psig boost; 3.48 pulley), 400 RWHP/377 RWTQ, 8.8lbs/BHP; Dennis Reinhart Cobra engine cooling kit TRANSMISSION: Stock transmission upgraded with Performance Automatic "Super Streeter" transmission version, stub shaft (defective metal) failed at 30k miles; upgraded internals (except for torque converter) to Reinhart's design; Precision, triple disc, P/N469018-3, later upgraded to 3500 rpm stall speed); Ford Racing transmission aluminum pan SUSPENSION: Metco control arms (black powdered coated), coil from each front stock spring removed to produce the “same” effect as an Eibach spring DRIVETRAIN 4.10 gears, MMX Driveshaft, Ford Racing Stud and Girdle BRAKES:14 in. BaerClaw front, (two piston, slotted rotors), TIRES: Pirelli P-Zero Asimmetrico (front 255/45ZR18, rear widened rims 285/45ZR18), ACCESSORIES: Wheel locks (Ford), godshead valve stem caps, KB Dead pedal, Badgeless front grille by “Zack”; Zaino waxing; RainX; 3M protective film, FordChip, Ground clearance: 5 in. MISCELLANEOUS 18.5 mpg at a steady speed of 80 mph, one tank of gas
______________________________ ___________________________
(Gone) 1961 Ford Galaxie, 2 dr. Club Victoria, 390CID, 375hp, 4 barrel
