Results 1 to 8 of 8
Thread: Interior diming lights
    I just noticed, that if I remotely unlock the car, the interior lights do not come on, is this part of the light module has any one else had this happen,
    Apr 2005
    The Pitt, PA
    Are you sure the after-market alarm hasn't taken over control of that function? In other words, does the after-market alarm simply send a lock/unlock trigger or does it trigger the LCM as the factory remote does? If the AM alarm simply sends a lock/unlock trigger, the LCM will not know to turn on the interior lighting.
    2013 Ford Taurus SHO
    #1649
    boi
    Its a good point, I will try the factory remote, but it did work with the AF alarm. Also I think if the car is locked and you unlock it with the door key pad as you press the first number, the lights are supposed to come on and they do not
    Jan 2007
    Baltimore County / Overlea
    Quote Originally Posted by Dennis Reinhart View Post
    that is correct...The lights ARE supposed to come on... check the wiring of the alarm!
    Apr 2005
    The Pitt, PA
    You are correct. The keypad should work regardless of the alarm...
    This may seem simple, but make sure your interior dimmer is not all the way over into the extreme left (no dash lights) or extreme right (cabin lights always on) position. Check the interior lights fuse: Inside box #21 15A.
    #1649
    boi
    Oct 2003
    Beaufort, SC
    Electrical system going BAD....sell it to me ASAP....CHEAP!!!
    Member #1368
    2004 Silver Birch...300A
    #948 of 3213/#8787 of 11052
    FIT "ProCharger" #0010
    Real AutoMeter Oil Pressure Gauge
    Addco Anti-Sway Bars
    ScanGauge II In Dash
    Nitto 295's On Widened Rears
    Mach I Air Dam
    It is the AF alarm Rich the lights come on with the key pad and the OEM remote
    Apr 2005
    The Pitt, PA
    If it was worth your trouble, you could have and output from the alarm brain send a trigger to the LCM for interior light control.
    You gotta lotta stuff in that car at his point, though. You could run the risk of causing a different problem just by going into it.
    #1649
    boi
  1. This freaked me out (lights cutting out).
    By Meteorite in forum Shop Talk
    Last Post: 03-07-2007, 12:16 PM
  2. Fog Lights switched
    By Architect in forum Shop Talk
    Last Post: 07-19-2005, 08:06 PM
  3. reverse lights
    By hdwrench in forum Shop Talk
    Last Post: 01-30-2005, 08:08 PM
  4. Marauder Has Good Showing @Drag Strip
    By sailsmen in forum Community Discussion
    Last Post: 10-04-2004, 05:05 AM
  5. Daytime Running Lights
    By Black Terror in forum Community Discussion
    Last Post: 07-26-2002, 10:13 PM
