a maf problem would not cause a bank specific lean or rich problem....if maf were faulty both banks would have similar issues..same rule goes for fuel filters, pumps etc....the likely cause here is an o2 senser that intermittenly stops switching...it is most likely worn/damaged. i see this all the time at the dealer. as stated above you dont need the parts store to clear the code. just disconnect the battery for a few minutes.....this will clear the code and the KAM (keep alive memory)
former owner...2003 marauder black
vortech air/air reichard 3.4 pulley
dr exhaust w/ mac stainless mufflers
baer 14in brakes, stainless hoses
4.30's
31spline mosers, auburn pro, tfs girdle
dynotech shaft
305 nittos
sold!
