A/C works fine... and turns off with the normal noises.
But now when I turn it on.... there is a really loud clunking noise coming from behind it. Any ideas?
Could be the clutch in the A/C compresser?
Member # 383.
2003 Marauder Black.
Build 8/13/02
Launched 9/28/02
Sold May 16, 2018
#3,646 of 7,839 black '03
Every once in awhile my crown vic will do that but it works fine.
There are shims behind the clutch plate that can be removed one at a time to "tighten" the gap and minimize the slap you hear when the clutch engages!!! There is a special tool used to hold the clutch while you remove the center bolt holding it....I rented it from AutoZone!!
Minimizing the gap will also help minimize wear when the plate engages!!
Give it a try....it's easy and you might be pleasantly surprised!!
Marauderjack
Are you guys talking about the belt driven A/C Compressor on the engine?
That is not what I'm talking about. I know that makes more noise than I'm used to also.... but I know that's normal.
This noise seriously sounds it's coming from under the dash right behind the oil/volt gauges. Sounds like someone is punching 200 sheets of notebook paper. Loud.
Not the A/C Compressor.
We have air conditioning? or are you talking about alternating current? All I use is HEAT!!
Marauderless....
That's the doors (forgot what it's called) that mix outside air with A/C air to get the cabin temp you want...It's normal...
ALOHA
'03 A Build Date 8/02
F.I.T. #6 ***RESURRECTED***
*444 RWHP / 401 RWTQ
*10 lbs. Boost
*P1SC1 ProCharger
Blend Door?
2003 300A BLACK DD
Sequence # 4569 of 7839
Silver Inserts / K&N CAI / Drilled - Slotted Rotors
DR Xcal2/Under drive pulleys (thank Rich)/180 T-stat
EMP water pump / Denso irridiums (thanx Rich)
Diamond Plate Radiator Cover and Air Dam, made by and broken in by magindat.
Custom Embroidered SB Head Rests (Thanx Rich & Rex)
Running with no mufflers, makes me sound fast!!
Upgraded Sound System (John's Stereo)
-Pioneer AVIC-D3 w/ XM & iPod
-Pioneer Premier Speakers
-MTX TC3001 Amp
-MTX 10" Sub w/ Custom Box and LEDs (magindat)
adopted 6/12/07 - 20,956 Miles
SOLD 2/23/13 - 73,286
Contemplating a battery handle delete
^^^That's it!!!
Thanks, Brutha
ALOHA
*10 lbs. Boost
*P1SC1 ProCharger
I was thinking it was the blender.... but I've never heard any that loud.
And when I say loud.... I mean... I can hear it over the music, even when it's turned way up.
Loud!
I guess I am going to have to do some digging this weekend.
It may be sticking and when the vacuum gets low enough like 15 MM of Hg, it may break loose. Usually they move slowly as vacuum evacuates the air motor. You should be able to watch the arm... When the noise happens you should be able to feel a drastic change in the temp of the air coming thru the vents
