How do i fix this please,starts but wont hold, stalls a few seconds after.
P0320
Ignition/Distributor Engine Speed Input Circuit Malfunction
<!-- / message --><!-- sig -->__________________
P0320
6621 of 7839.
R.I.P
<TABLE cellSpacing=0 cellPadding=3 border=1><TBODY><TR><TD vAlign=top align=left>P0320 - Ignition Engine Speed Input Circuit Malfunction </TD><TD vAlign=top align=left>The ignition engine speed sensor input signal to PCM is continuously monitored. The test fails when the signal indicates that two successive erratic profile ignition pickup (PIP) pulses have occurred. </TD><TD vAlign=top align=left></TD><TD vAlign=top align=left>The DTC indicates that two successive erratic PIP pulses occurred. </TD></TR></TBODY></TABLE>
- Loose wires/connectors.
- Arcing secondary ignition components (coil, wires and plugs)
- On board transmitter (2-way radio)
Think the problem is my alt. died, it runs with booster cables from my other car, so you where right in a way about the misfires.
6621 of 7839.
R.I.P
Turns out no alt. are available, back order at ford, could be weeks or even months waiting they told me, so the hell with them, went and called dennis for the 200 amp kit.
6621 of 7839.
R.I.P
