Results 1 to 15 of 16
Thread: HELP right rear axle seal...
    Jun 2004
    I was removing the snows tonight. The inner right rear wheel was coated in grease and it was running down the side of the tire. I am assuming its the axle seal as the brakes are fine. Is it driveable like this? -or- should I let it sit in the driveway until I can get into the garage? Thanks.
    Sep 2005
    South Florida
    Wecome to the world of New axle replacement. The dreaded soft axle shaft has struck another fine Marauder owner. Don't worry it's a big club.
    TCE
    My Garage
    Purgatory, FL
    I've heard of just seals going on 2004s. But it is still a tossup until the axle is removed.
    (#6178 in black per FPIC)
    Rest In Peace:
    Paula Babineau 1/9/67-8/2/11
    Rex Weinbender
    Peter
    Sep 2005
    South Florida
    Quote Originally Posted by RoyLPita View Post
    WHAT! A seal go, in a Mercury, Naw, It's a myth.
    TCE
    My Garage
    Jun 2004
    Thanks guys, but is it driveable?
    Purgatory, FL
    I wouldn't put more miles on it before it gets fixed or else a full overhaul would be expected.
    Rest In Peace:
    Rex Weinbender
    Peter
    Jan 2008
    Cincinnati,Ohio
    welcome to the club,. i'm a member too!!! 3weeks after adoption and i had to join by submission..... and i'm proud.
    Jan 2008
    Cincinnati,Ohio
    P. S. there's also an axle kit for under 400. that you can install yourself. it cost me a grand to figger that 1 out.
    Jan 2008
    Houston
    Silly ?, but do you have an extended warranty? Mine was covered when I had it replaced.
    Jun 2004
    Thanks, I'll let it sit. I believe it happened this afternoon. And, NO extended warranty...
    Hmmm that reminds me to check mine soon.
    300B
    Exhaust by Greg
    2015 Ford Focus SE Sport FWD
    2010 Ford Fusion Sport FWD
    Jun 2004
    I believe I got lucky as there was not alot of grease in wheel and it was running down the side of the tire when I removed it. No spots in the driveway, so I believe it just happened. Hoping the ten miles to the dealer's shop doesn't do too much damage. Was going to have the rear brakes redone in a few weeks anyway, so I guess that is being done sooner. I wonder what they'd charge to do 4.10s as long its apart anyway???
    Aug 2004
    Fairfield, PA
    You may want to call Wes at Innovative Interceptors and get a proper rear cover with stud & girdle kit, to replace the pizza pan that holds the juice in, now.
    Remembering that attention to instillation details are important to keep the replacement from leaking.
    Jun 2004
    The Final Outcome
    Turns out both sides are bad, new seals did the trick. Rear brakes replaced, Manager said the e brake was "toast, completely gone". Must have hung up as I don't use it routinely, only when car is jacked up for work. Spring that works on posi toast. Thats why I don't have the car back yet as he had to order it. Maybe tomorrow. Still waiting for the bill. but, he said he only has a couple hours into it plus parts. These guys are good to me, charge actual hours worked, not book time. It also helps that their rates are quite reasonable for a FLM dealer, $60 hr.
    Long Island, NY
    Quote Originally Posted by Blackmobile View Post
    According to FMC Marauders with soft axels were produced prior to 1-1-2003.
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    Mercury All Weather Mats
    1973 Oldsmobile Toronado
    2012 Kia Sedona Van
    2008 Corvette Convertible
    2021 Prius Prime Limited
    Member # 440
    ----- John
  1. Rear end leaking
    By MMM2003 in forum Shop Talk
    Last Post: 08-13-2007, 06:20 AM
  2. 15,000 Mile Service - Rear Main Crank Seal
    By Blue03 in forum Shop Talk
    Last Post: 04-29-2006, 12:40 PM
  3. Stud & Girdle Kit & Rear bar clearance
    By Svashtar in forum Shop Talk
    Last Post: 01-07-2005, 10:26 PM
  4. Axle Housing Broke
    By Agent M79 in forum Shop Talk
    Last Post: 03-11-2004, 07:52 PM
  5. Rotating Clicking sound from rear axle area
    By 03mmmonroe in forum Shop Talk
    Last Post: 02-07-2004, 05:13 PM
