Searched but not found. I found oil in my spark plug tube (the cylinder closest to firewall on passenger side, not sure of #), so it is leaking past the o-ring or grommet at that location. Considering what a PITA it is to remove the valve cover, how likely is it for the o-ring to be trashed versus improperly seated?
I don't know the details (Marauder 57 didn't tell me work was done on the head(s) til after I bought the car and found a loose head bolt hanging in the hoses on the drivers side fender), but at least one head was worked on by a sloppy tech, and most of the valve cover bolts were slightly loose when I decided to check things with a wrench after finding the stray head bolt.
I've known of a slight oil leak/seep from the rear of the passenger valve cover for most of the time I've owned the car, and figured it was the cover's gasket. Now I wonder if maybe it was the o-ring?
I didn't notice or realize what I was seeing, perhaps, when I changed the plugs for the first time 12K miles ago, so a build up would have drained into the chamber when I removed the plug. I vaguely recall wet threads on at least one plug. At the time I kind of figured oil leaks would be normal for a high performance v8 being bought used (no longer loved by the seller) and with 69K miles.
Has this happened to anyone else? Should I expect to be able to re-use the o-ring, or buy a new set?
by the way, don't pay attention to the following smilies - my 3-yr old wants to add some for fun:
